Current time: 06/11/2026, 17:13 Hello There, Guest! (Login — Register)
(21/04/2016 15:31)Dentonian Wrote:  Isn't there normally some (minor?) timetable changes in mid-May? I was referring to the Hope(less) Valley line. Whilst I can't find any changes on this line for May, I was using bus industry logic in wondering whether changes elsewhere would result in a "vehicle" schedule re-write meaning trains allocated more suited to capacity demands.
At the end of May, any unit diagram changes will happen at the same time, but given that the number and type of units the franchise has isn't changing yet, then I doubt much will change.
Service level in the PTE areas is specified by them anyway.
SD.
(21/04/2016 18:45)St Helens Rider Wrote:  Are the 319's getting Wifi? If so, it will probably be then when they get painted as they have already been refurbished.
They will need to go for new accessible toilets to be fitted before 2020 too.
SD.
319380 failed for a second day in a row,replaced by 319375.
Oh dear the curse of the 319's starts striking again.
(23/04/2016 21:15)Gordon V Wrote:  319380 failed for a second day in a row,replaced by 319375.
They've managed a week of no breakdowns, well none have been reported over the past week
(24/04/2016 06:19)RedPanda Wrote:  They've managed a week of no breakdowns, well none have been reported over the past week
I can dispell that in that 319382 failed on the 19th April before working the 2147 Lime St to Preston and it was sent to Allerton depot and replaced by 319365.
(24/04/2016 06:38)Gordon V Wrote:  I can dispell that in that 319382 failed on the 19th April before working the 2147 Lime St to Preston and it was sent to Allerton depot and replaced by 319365.
I was thinking this can't be possible for the 319's to go a week with no failures
(24/04/2016 08:17)RedPanda Wrote:  I was thinking this can't be possible for the 319's to go a week with no failures
They can barely go a day without failing let alone a week!
Another day,more 319 failures,319368 failed meaning the 0633 Lime St-Wigan and 0731 Wigan-Lime St were cancelled and 319379 failed meaning that the 0602 Man Vic-Lime St was cancelled
(25/04/2016 06:06)Gordon V Wrote:  Another day,more 319 failures,319368 failed meaning the 0633 Lime St-Wigan and 0731 Wigan-Lime St were cancelled and 319379 failed meaning that the 0602 Man Vic-Lime St was cancelled
Do we know what the most common reason for a failure with the 319's?
