Current time: 05/11/2026, 20:05 Hello There, Guest! (Login — Register)
A few more new ones up include:
Valid from 1st August 2012:
107/207/208 (Woodside or Town Meadow - New Brighton)
The services are unchanged, but are now shown in this separate leaflet.
Route 407 is now also shown in a separate leaflet.
http://merseytravel.gov.uk/pdf/tt_100/10...02012).pdf
407 (Liverpool - Town Meadow)
Route 407 is unchanged, but is now shown in this separate leaflet.
Routes 107, 207 and 208 are now also shown in a separate leaflet.
http://merseytravel.gov.uk/pdf/tt_400/40...02012).pdf
No changes on those two, they are just split into separate timetables!
Valid from 20th August 2012:
20/21/242/821 (Liverpool - Tower Hill or Northwood/Netherton - Liverpool)
Route 852 is renumbered 821 and is now shown in this timetable.
The bus now starts from Netherton at 0554 and finishes at Liverpool ONE Bus Station at 0630.
(Routes 20, 21 and 242 are unchanged.)
http://merseytravel.gov.uk/pdf/tt_001/20...02012).pdf
830/831 (Liverpool - Netherton)
Route 830: the morning bus that leaves Mann Island at 0458 is withdrawn. (The afternoon bus is unchanged.)
(Route 831 is unchanged.)
http://merseytravel.gov.uk/pdf/tt_800/83...02012).pdf
Valid from 2nd/3rd September 2012:
2 (Southport - Preston)
The 0758 Monday to Friday bus from Preston to Southport is retimed to run 5 minutes earlier.
(All the other times are unchanged.)
http://merseytravel.gov.uk/pdf/tt_001/02...02012).pdf
X2/2X (Liverpool - Southport/Southport - Preston)
Route X2: the 1420 Monday to Friday bus from Southport is retimed along the route.
Route 2X: Monday to Friday buses departing Southport at 0717 and 0742 may now run up to 15 minutes earlier in Lancashire during school holidays.
10/26 (Cronton - Widnes or West Bank)
Route 26: the Saturday service is withdrawn.
(Route 10 is unchanged.)
http://merseytravel.gov.uk/pdf/tt_001/10...02012).pdf
12/13 (Liverpool - Stockbridge Village circulars)
The Monday to Friday daytime frequency of both services is increased to 10 minutes and some times are changed.
http://merseytravel.gov.uk/pdf/tt_001/12...02012).pdf
20/320/620 (St Helens - Earlestown, Ashton-in-Makerfield, Wigan or Hindley Green)
Route 20: the frequency is reduced to every 20 minutes, the times are changed and all buses now run between Earlestown and St Helens.
Route 320: the Monday to Friday daytime frequency is increased to five buses each hour and the times are changed.
Route 620: the times are changed.
44/45/46 (Garston, Stockbridge Village or Wavertree - Widnes (Riverside College) or Astmoor College)
Route 44: buses are extended, via Runcorn, to start and finish at Astmoor College.
(Routes 45 and 46 are unchanged.)
http://merseytravel.gov.uk/pdf/tt_001/44...02012).pdf
61/161 (Bootle - Aigburth Vale)
Arriva Route 61: the Monday to Friday daytime frequency is increased to 12 minutes and some times are changed.
(Route 61 operated by ACE Travel and Route 161 are both unchanged.)
http://merseytravel.gov.uk/pdf/tt_001/61...02012).pdf
81/81A/81E/181/881 (Bootle - Speke or Liverpool John Lennon Airport/Bootle - Jaguar Land Rover Factory)
Arriva: the Monday to Friday daytime frequency is increased to a combined 10 minutes and some times are changed.
(Route 81 operated by ACE Travel and Routes 881 and 881 are unchanged.)
http://merseytravel.gov.uk/pdf/tt_001/81...02012).pdf
156/256 (St Helens - Garswood or Ashton-in-Makerfield/Garswood - Ashton-in-Makerfield circular)
Route 156: Monday to Saturday daytime buses run by Arriva now run 5 minutes later.
Route 156: the evening times at Blackbrook are changed by 2 minutes.
http://merseytravel.gov.uk/pdf/tt_100/15...02012).pdf
Interestingly no new 181 (Arrowe Park Hospital - Leasowe station) has been published yet - This is one of the services that A2B began operating from this week, taking over from Avon Buses. No new times so the old timetable isn't going to really cause any confusion to passengers but odd it seems to have been missed out!
With the 20's being curtailed to Earlestown, I have heard that the 34A is being extended to Bradleigh Estate as a replacement, so it will be interesting to see what happens with both the 34 and 34A timetables from this date.
That's indeed correct St Helens Rider as the 34A has the time to do so! I assume curtailing the 20 and replacing the Bradlegh Road section with the 34A means they can reduce the PVR which would explain the change.
if what i heard is true this is only the start and wheres the 10A timetable as i think it changes aug 29th?
There's not huge changes planned other than that. The only other significant one will be the re-routing of 33s at the Thatto Heath end of the route so that after Queensland, they turn right at the lights and head back toward St Helens leaving the Suttons industrial park section of the route served by just the half hourly 33A due to a lack of patronage around that loop.
There's also a timetable change on the 32/32A as well I believe.
i hear the 32 will lose one bus an hour but unconfirmed
The changes are likely to be slightly more complex than it just loosing one bus an hour. A bus will be lost but, not all day. Instead it'll be taken off late morning to go back on at some point during the afternoon. It's all to do with the re-introduction of split shifts to the depot.
yes that true and same applys to the 33 also i hear 23 is to return for eve only dno what that is aldo i did hear about the 20 thing a few month back and 34A thing a same time, 620 apparently for atherton if true i will stop my protest as i will be happy with that as atherton a good place
User(s) browsing this thread: 57 Guest(s)
