Current time: 19/10/2026, 02:01 Hello There, Guest! (Login — Register)
Bus Tracking Website
RE: Bus Tracking website
A Few Arriva North West Buses are showing on the tracker
(09/09/2019 11:02)T42 PVM Wrote:  A Few Arriva North West Buses are showing on the tracker
Virtually all have appeared in the last half hour....screenshot attached.
HTH
Attached File(s) Thumbnail(s)
(09/09/2019 11:32)gka472l Wrote:  Virtually all have appeared in the last half hour....screenshot attached.
HTH
I've just got back from the shops. You beat me to it. This is another step in enabling the undecided who have a negative view of all things buses to reconsider whether to leave the car at home.
(09/09/2019 11:52)Barney Wrote:  I've just got back from the shops. You beat me to it. This is another step in enabling the undecided who have a negative view of all things buses to reconsider whether to leave the car at home.
I've also noticed Arriva Yorkshire & North East have appeared in full, presumably at the same time, as did much of Stagecoach a few weeks ago in it's entirety....
Most Buses have since gone from the map
(09/09/2019 12:32)T42 PVM Wrote:  Most Buses have since gone from the map
Yes, seems to have thinned out a bit, same with Yorkshire.....could be testing the feed or whatever?
(09/09/2019 12:42)gka472l Wrote:  Yes, seems to have thinned out a bit, same with Yorkshire.....could be testing the feed or whatever?
All of Arriva NWW seem to be on now.
(09/09/2019 15:02)Barney Wrote:  All of Arriva NWW seem to be on now.
Came back fully about half an hour ago, but they seem to be thinning out again......
(09/09/2019 15:06)gka472l Wrote:  Came back fully about half an hour ago, but they seem to be thinning out again......
You will find it keep coming on and off for a day or so after they appear but should then settle down to be more reliable. It often does that after new fleets appear.
(09/09/2019 17:01)PSbusdriver Wrote:  You will find it keep coming on and off for a day or so after they appear but should then settle down to be more reliable. It often does that after new fleets appear.
Indeed, found Stagecoach was like that a couple of weeks back when all the Merseyside & Manchester fleets appeared, now consistently on. The website must use an awful lot of bandwith to get all that data.....incindentally, it seemed to be most Arriva fleets appearing today as Yorkshire, North East and most of the remaining bits of Midlands also appeared....didn't check further south though
