Current time: 02/11/2026, 15:51 Hello There, Guest! (Login — Register)
is it 508143 that has had the severe graffiti attack?
That is one but another one is also tagged badly.
Cheers for that info CX06 EBK I thought 507007 was in Beatles wrap not sure why
(15/07/2013 21:44)snowey Wrote:  Yet Angel:
Sounds promising! I like the advertising liveries a lot - they certainly brighten the place up.
507007 is normal Andy but it does still have its Liverpool 08 logos which are just a bit outdated now.
indeed is 507007 that unreliable unit that seems to fail a lot on Ormskirk line
(16/07/2013 14:57)CX06 EBK Wrote:  That is one but another one is also tagged badly.
I seen two units (the front unit of a six-car set and one three-car unit - a rare sighting for a weekday evening?) on the Ormskirk line this evening with heavy grafitti on their front coaches (they were Liverpool-bound, if that helps at all!).
another one Class 508 normally on Chesters is badly Grafittied and looks a real mess
As already mentioned, 508120, 508126 and 508143 are the three units noted recently with graffiti. It is quite severe on 126 and 143 but just a small blue tag on 508120.
508139 is currently on Southport diagrams and set on the northern line. Presume with the loop line shut and being told that the stock interchange is out of action that it will stay on northern line turf until the works are finished?
(16/07/2013 19:50)507 mad Wrote:  508139 is currently on Southport diagrams and set on the northern line. Presume with the loop line shut and being told that the stock interchange is out of action that it will stay on northern line turf until the works are finished?
Previous times the loop has been closed, the stock interchange has remained in use albeit less frequently than usual. Assume this is the case again now, so 508139 and the graffitied units should transfer over before long.
