Current time: 06/11/2026, 02:04 Hello There, Guest! (Login — Register)
507023 is another unit to be badly attacked. Grafitti over Operations inspector Stuart Mason's name plate...
Wirral Line currently messed up due to police incident at Birkenhead Park
The Wirral Line service was disrupted badly for a while .
Chester / Ellesmere Port services couldnt travel beyond R Ferry
New Brighton services were not running.
West Kirby services couldnt run beyond Bidston.
Chester station completely evacuated.
Merseyrail service report to be alight on Platform 7.
(1945 from Liverpool Central, 2030 from Chester)
Someone is in for a rather large bill!
Station now reopened with substantial disruption, and, I assume, a unit stuck on Platform 7!
A rail replacement bus service , provided by Arriva Birkenhead is now in operation.
Platform 7 still not available for use .
Service restored at 2140.
Seems its not been a good week for services in South Wirral , earlier in the week there was service disruption on the Ellesmere Port line .
507003 is the culprit.
Not too sure what has happened. 4 fire engines turn up and entire station evacuated, but on twitter, Merseyrail deny that a fire occurred, despite several people asking specifically about a fire.
Bit too much for a plastic bag in a resistor fan, so must have been something pretty unusual.
(06/09/2013 20:57)First Class Wrote:  507003 is the culprit.
Im led to believe the unit was switched off and the unit was still smoking away .
I dont know whether its the higher propensity to pick up plastic bags at speed that is the problem that then stick to the housing thats the problem.
For once the old plastic bag wasn't to blame!
It was a fault with the resistor fans
It was a fault with the resister
User(s) browsing this thread: 48 Guest(s)
