Current time: 04/11/2026, 16:48 Hello There, Guest! (Login — Register)
Arriva Buses Wales - Wrexham Depot
RE: Arriva Buses Wales - Wrexham Depot
(12/12/2017 14:55)LJ51 DDA Wrote:  2801 is the one that went to Speke its back in Wrexham now both 2801/02 are Withdrawn but are classed as pool buses there never out anymore they were replaced by 669/670, the Versa's can usually be found on the 1,5,7,8,32,33 Smile
998/999 will not be moving until replacements have arrived and its confirmed Wrexham is having Solo SRs now, due to route changes again there will be no need for Cadets Smile
Thanks both. Much appreciated.
Does anyone know if 2803 is likely to see any further use from store at Laird Street to perhaps rejoin 2801/02 or has it donated any parts?
(12/12/2017 15:17)Depotosw Wrote:  Does anyone know if 2803 is likely to see any further use from store at Laird Street to perhaps rejoin 2801/02 or has it donated any parts?
I've been informed that 2803 is now done and withdrawn too
Does anyone know what route 711 is on today (if its in service) im planning to come to Wrexham today to find it.
(13/12/2017 10:11)darylyates17 Wrote:  Does anyone know what route 711 is on today (if its in service) im planning to come to Wrexham today to find it.
Daft as it sounds, hang around bus station and if its out you will see it. Most services interwork between quite a few routes expect routes 1 and 5 where you are very unlikely to find it on those two (it has appeared on the 1 before the E400MMC Citys appeared when they were very short).
(13/12/2017 10:42)Depotosw Wrote:  Daft as it sounds, hang around bus station and if its out you will see it. Most services interwork between quite a few routes expect routes 1 and 5 where you are very unlikely to find it on those two (it has appeared on the 1 before the E200MMC Citys appeared when they were very short).
It worked I waited for about half an hour and got it on the 8 to Caia Park it was on the 33 before and after I got on it
Recently confirmed Optare Solo SRs 705/709 are moving from Bolton to Wrexham of which will displace Versa's 998/999 to Bangor Smile
(19/12/2017 19:35)LJ51 DDA Wrote:  Recently confirmed Optare Solo SRs 705/709 are moving from Bolton to Wrexham of which will displace Versa's 998/999 to Bangor Smile
Same source of info also states 2802 reinstated and 2801 may follow.
I guess another trip to Wrexham (like I did for 711) is needed then since im after all of the Solo SRs I just need the other 10 that didn’t go to St Helens as I’ve been on all of the St Helens ordered ones except 718
(19/12/2017 22:55)darylyates17 Wrote:  I guess another trip to Wrexham (like I did for 711) is needed then since im after all of the Solo SRs I just need the other 10 that didn’t go to St Helens as I’ve been on all of the St Helens ordered ones except 718
Have you seen the 2 at Runcorn 708/709 they work the 3A/3c
