Current time: 29/11/2026, 09:19 Hello There, Guest! (Login — Register)
Upcoming service changes in Merseyside
RE: Upcoming service changes in Merseyside
(14/02/2025 10:30)Liamkennedy2231 Wrote:  Here’s the link:
https://online1.snapsurveys.com/ArrivaClickSpeke
I’ll attach a picture I got sent of the poster as well for authenticity, as I know the link doesn’t look too official
How good of Merseytravel to have a bus consultation but not post it on the BUS CONSULTATIONS webpage.....
(19/02/2025 20:00)iMarkeh Wrote:  How good of Merseytravel to have a bus consultation but not post it on the BUS CONSULTATIONS webpage.....
I think it mainly affects Arriva Click passengers so it's based on the Arriva Click buses and also bus stops surrounding the areas as their using the consultation to find passenger patterns ect. to run the service smoothly for those in the Speke area.
(20/02/2025 14:58)Merseysidebusenthusiast Wrote:  I think it mainly affects Arriva Click passengers so it's based on the Arriva Click buses and also bus stops surrounding the areas as their using the consultation to find passenger patterns ect. to run the service smoothly for those in the Speke area.
And what about those who don't use the Click service because... DRT and all it's problems. None users of Click may still want to voice their opinions on a proposed scheduled local bus service.
(21/02/2025 20:50)iMarkeh Wrote:  And what about those who don't use the Click service because... DRT and all it's problems. None users of Click may still want to voice their opinions on a proposed scheduled local bus service.
New service 211 will replace the current Click Speke Zone from Monday 14th April. Clicks operation will finish after service on Saturday 12th April.
The Click Sprinters will then be withdrawn and up for disposal.
Anyone aware of any bus service changes in April?
(10/03/2025 09:48)Merseysidebusenthusiast Wrote:  Anyone aware of any bus service changes in April?
Current changes showing up on the OTC database are.
13th April
Stagecoach 10A - Route and timetable changes
Stagecoach 217 minor route and timetable changes
Arriva Airport routes are having stand changes in the Airport.
Arriva 12/13 - Timetable changes
Arriva 15 - Timetable changes
The 211 should also be starting in April.
Bus Changes: 30th June 2025
Service: 22/22A
Old Service
22: West Kirby - Chester
New Services
22: West Kirby - Heswall - Parkgate - Neston - Willaston - Chester
22A: West Kirby - Heswall - Parkgate - Neston - Ness Gardens - Burton - Puddington - Chester
Service Changes
Service 22: Service is reduced to every two hours.
Service 22A: New two hourly service operating between West Kirby and Chester via Heswall, Parkgate, Neston, Little Neston, Ness Gardens, Burton and Puddington on Monday to Saturday Daytime operated by Al's Coaches.
Timetable Links:
22: https://jp.merseytravel.gov.uk/swe-ttb/T...a1b_TP.pdf
22A https://jp.merseytravel.gov.uk/swe-ttb/T...71d_TP.pdf
(21/05/2025 15:03)Jw88 Wrote:   Bus Changes: 30th June 2025
Service: 22/22A
Old Service
New Services
Service Changes
Timetable Links:
22: https://nationaljourneyplanner.traveline...537_TP.pdf
22A https://nationaljourneyplanner.traveline...b28_TP.pdf
So what does the 22A vary with the 22.
(22/05/2025 16:34)Merseysidebusenthusiast Wrote:  So what does the 22A vary with the 22.
There is not much difference between the two routes, a reduction for the 22 to every two hours the 22A will then operate every two hours to that gap, for example 22 at 8am and 10am then 22A at 9am and 11am.
The main change is the route. The 22A will serve Ness and Burton, while the 22 will continue through Willaston whose service will be reduced to every two hours.
Looking at the timetable there is also a difference in operation around Little Neston which may cause confusion for passengers around Mellock Lane, the 22 will continue via its current route (West Vale, Marshlands Road, Little Neston then to Chester) However the 22A will go the opposite direction. according to the timetable (Little Neston, West Vale, Marshlands then to Ness/Burton). Therefore journeys towards Chester will operate on both sides of the road... 22 on the same side as the Royal Oak, and 22A the side opposite the royal oak and journeys to West Kirby vice verica which is bound to cause to confusion.
Mollington also appears to be served on Saturdays according to the timetable.
I have also edited the timetable above, it no longer appears to work, it did at the time of posting.
