Current time: 06/11/2026, 02:49 Hello There, Guest! (Login — Register)
(04/09/2012 07:28)Its a hobby Wrote:  Thats funny the 30 was withdrawn a few weeks ago now! Thanks for the update Merseytravel
I think Merseytravel have gone by the official withdrawal date, rather than when the 30 actually stopped running!
Valid from 16th/17th September 2012:
14/14A (Liverpool - Widnes)
The times are changed.
Saturday afternoon buses no longer serve Dale Street or Lord Street in Liverpool city centre.
http://merseytravel.gov.uk/pdf/tt_001/14...02012).pdf
86C/86D (Liverpool - Childwall circular)
The frequency is increased to every 12 minutes and the times are changed.
http://merseytravel.gov.uk/pdf/tt_001/86...02012).pdf
Valid from 7th October 2012:
38/152/356 (St Helens - Rainford circulars)
Route 152: the service is now operated for Merseytravel by HTL Buses.
The 1705 bus from St Helens Bus Station now serves Kings Moss before Rainford.
(Routes 38 and 356 are unchanged.)
http://merseytravel.gov.uk/pdf/tt_001/38...02012).pdf
897/898/899 (Huyton Industrial Estate - Kirkby Admin/Page Moss - Kirkby Admin - Page Moss)
Early morning Route 897 and 898 buses now also run on bank holidays. (All other times are unchanged.)
(Route 899 is unchanged.)
http://merseytravel.gov.uk/pdf/tt_800/89...02012).pdf
901 (Leasowe - Moreton)
The service is now operated for Merseytravel by Cumfybus.
http://merseytravel.gov.uk/pdf/tt_900/90...02012).pdf
From the above contract changes, 152 is currently operated by Cumfybus and 901 by A2B Travel.
New 78 & 81s also online from October
Thanks! Those two didn't seem to be online earlier!
78 (Liverpool - Halewood)
The Monday to Saturday frequency is reduced to 30 minutes.
http://merseytravel.gov.uk/pdf/tt_001/78...02012).pdf
81/81A/181/881 (Bootle - Speke or Liverpool John Lennon Airport/Bootle - Jaguar Land Rover Factory)
Arriva: Route 81E buses are renumbered 81 and are extended to run from Hunts Cross to Speke.
(All other times and services are unchanged.)
http://merseytravel.gov.uk/pdf/tt_001/81...02012).pdf
Valid from 5th September 2012:
34/34A (St Helens - Newton-le-Willows or Leigh)
Timetable reprinted.
http://merseytravel.gov.uk/pdf/tt_001/34...02012).pdf
Odd though as this timetable was only last issued on 2nd September 2012 (when the change was 'Route 34A is rerouted to serve Bradlegh Road, replacing a part of Route 20. The times are changed.') so I assume there was an error in the original one?
As a regular user of 34, just at a glance, I can't tell any difference to the 2nd September timetable.
There is a correction on the map page. At least the GM portion is on the map now, even if it is squashed in scale-wise on the edge of the page!
Just one so far today!
160/161/162/163/164/165 Formby Village Circulars
The services are now operated for Merseytravel by ACE Travel.
(The routes and the times are unchanged.)
http://merseytravel.gov.uk/pdf/tt_100/16...02012).pdf
Travel News Update
Planned changes between 16 - 22 September 2012
http://www.merseytravel.gov.uk/articleim...202012.pdf
The following services are changing on 16 September:
The times will be changed. Saturday afternoon buses will no longer serve bus stops in Dale Street or Lord Street or Victoria Street.
86/86A/86C/86D (Liverpool - Allerton, Childwall, Garston, Liverpool South Parkway or Liverpool John Lennon Airport)
The normal timetable is re-introduced. Buses will run more often and the times will be changed.
X36 (Liverpool John Lennon Airport – Ellesmere Port)
This service will only run between Runcorn and Ellesmere Port, so will no longer serve Merseyside.
(04/09/2012 16:17)buses7675 Wrote:  Thanks! Those two didn't seem to be online earlier!
Can't believe they've reduced the 78s, they were busy enough at 20mins and now that the schools are back that route will just be hell!
Y472 KNF
