Current time: 06/11/2026, 15:00 Hello There, Guest! (Login — Register)
High Peak
RE: High Peak
The 20:15 199 service from Manchester Airport failed on the M60 motorway just before Stockport
RE: High Peak
Oops not good! There's a steady batch of new 66 plate solos coming on stream although the older solos are still going strong.
The only oddball in the fleet is the white solo that's yet to be painted in high peak livery.
RE: High Peak
Derbyshire County Council reporting that High Peak's 62 and 62A services will be withdrawn at the end of March.
http://www.derbyshire.gov.uk/transport_r...efault.asp
RE: High Peak
(26/01/2017 06:58)33109 Wrote:  Oops not good! There's a steady batch of new 66 plate solos coming on stream although the older solos are still going strong.
Other Julian Peddle companies also have the odd long term white vehicle too - I wonder if they are his personal property?
RE: High Peak
Wouldn't imagine so really tbh as the white solos have high peak fleet numbers & branding.
RE: High Peak
Public Inquiry (75204) to be held at The Public Inquiry Room (Warrington), WA3 2SH, Suite 4, Stone Cross Place, Stone Cross Lane North, Golborne, Warrington, on 6 October 2017 commencing at 14:00 PC0001086 SN ERIC W BOWERS COACHES LTD Director(s): MATTHEW EVANS, KEITH HAYWARD 43 WENLOCK WAY, LEICESTER, LE4 9HR
S17 - Consideration of disciplinary action under Section 17 (The Public Passenger Vehicles Act 1981) S28 - Consideration of disciplinary action under Section 28 (The Transport Act 1985) S26 - Consideration of disciplinary action under Section 26 (The Transport Act 1985)
RE: High Peak
(09/09/2017 09:20)mikestone Wrote:  Public Inquiry (75204) to be held at The Public Inquiry Room (Warrington), WA3 2SH, Suite 4, Stone Cross Place, Stone Cross Lane North, Golborne, Warrington, on 6 October 2017 commencing at 14:00 PC0001086 SN ERIC W BOWERS COACHES LTD Director(s): MATTHEW EVANS, KEITH HAYWARD 43 WENLOCK WAY, LEICESTER, LE4 9HR
Any idea what this specifically relates to?
RE: High Peak
(09/09/2017 09:28)knutstransport Wrote:  Any idea what this specifically relates to?
To put it simply, it is either down to maintenance or being way below the 95% expected compliance (usually high levels of non running or very late running). Consequently, the TC could seriously consider cutting or revoking a license.
RE: High Peak
High Peak are to revise the 58 service from 26th March. The commercial Black Road circular will be cancelled from the same date, presumably the turnaround time on the 58 will be reduced meaning it'll be no longer possible to run it using the same vehicles.
RE: High Peak
(30/01/2018 17:14)knutstransport Wrote:  High Peak are to revise the 58 service from 26th March. The commercial Black Road circular will be cancelled from the same date, presumably the turnaround time on the 58 will be reduced meaning it'll be no longer possible to run it using the same vehicles.
Might be part of something bigger, such as the changes to the 392/3. Unless things have changed recently the 58 interworks with the 1,14, and 392/3 on a complex diagram, rather than a simple 58 - 1 -58
Edit : I think it’s 58 - 14 - 392/3 - 393/3 - 1 - 58 iirc.
