Current time: 29/11/2026, 12:31 Hello There, Guest! (Login — Register)
Upcoming service changes in Merseyside
RE: Upcoming service changes in Merseyside
(22/05/2025 19:59)Jw88 Wrote:  There is not much difference between the two routes, a reduction for the 22 to every two hours the 22A will then operate every two hours to that gap, for example 22 at 8am and 10am then 22A at 9am and 11am.
The main change is the route. The 22A will serve Ness and Burton, while the 22 will continue through Willaston whose service will be reduced to every two hours.
Looking at the timetable there is also a difference in operation around Little Neston which may cause confusion for passengers around Mellock Lane, the 22 will continue via its current route (West Vale, Marshlands Road, Little Neston then to Chester) However the 22A will go the opposite direction. according to the timetable (Little Neston, West Vale, Marshlands then to Ness/Burton). Therefore journeys towards Chester will operate on both sides of the road... 22 on the same side as the Royal Oak, and 22A the side opposite the royal oak and journeys to West Kirby vice verica which is bound to cause to confusion.
Mollington also appears to be served on Saturdays according to the timetable.
I have also edited the timetable above, it no longer appears to work, it did at the time of posting.
Isnt this a little similar apart from the alterations to the route to operate via West Vale and little Neston to the C22 and C23 prior to deregulation .
The old 22/23 and before that the C22/C23 used to have a similar set up - C22/22 every 2 hours via Burton and the C23/23 every 2 hours via Willaston. The difference being that til the early 90s neither bus diverted via Little Neston or West Vale. When that diversion was introduced, only the 23 from Willaston went via Mellock Lane , with both the 22 and 23 going via Greenfields and West Vale. This avoided buses going to same destination stopping on both sides of Mellock Lane.
The other difference is that only the 22 went via Parkgate, 23 going via Liverpool Road out of Neston.
The map of Neston showing the routes is at the back of the old Cheshire CC guide from November 1994 taken from the excellent Railwaymedia website
https://drive.google.com/file/d/1i4E1P-t...MBR_f/view
(26/05/2025 09:34)K10K11 Wrote:  The old 22/23 and before that the C22/C23 used to have a similar set up - C22/22 every 2 hours via Burton and the C23/23 every 2 hours via Willaston. The difference being that til the early 90s neither bus diverted via Little Neston or West Vale. When that diversion was introduced, only the 23 from Willaston went via Mellock Lane , with both the 22 and 23 going via Greenfields and West Vale. This avoided buses going to same destination stopping on both sides of Mellock Lane.
Interesting booklet to see how things have changed over the years .
The changes to the 22 will result in the buses via Puddington and Burton picking up nobody in either locations , its a very orientated area now
500 to go to every 15 minutes from 20th July
The 319 will be changing operators on July 20th as well, though the operator taking on the service is not yet known.
(25/06/2025 17:07)NathanR Wrote:  The 319 will be changing operators on July 20th as well, though the operator taking on the service is not yet known.
It is known . Preston bus
(25/06/2025 18:22)MPTE1955 Wrote:  It is known . Preston bus
Strange that Merseytravel haven't confirmed that information then, that was from just having a mooch on their website.
To be fair, I wasn't aware myself until I checked the Lancashire service changes thread and that's how I found out.
First time Rotala have operated on Merseyside as well
They come into Rainford on the 312
Was jcksmnr
(25/06/2025 23:02)Jack Wrote:  They come into Rainford on the 312
Didn't realise 312 came into Merseyside
User(s) browsing this thread:
