Current time: 06/11/2026, 06:54 Hello There, Guest! (Login — Register)
With the 75 running every 10 minutes, the 79 Running every 10, Its not viable with the only real route difference being Childwall.
They wanted to get rid of the 78 alltogether (or atleast replace with either a 75 or 78) so 4 buses is better then 0
I suppose you're right. Even so, if they're going to do this I think that they should at least think about upping the frequency of the 75, at least at peak times, the buses to Halewood are overcrowded as it is. Sometimes it seems as though they'd rather get rid of buses through Hunts Cross and Halewood altogether!!
Y472 KNF
Valid from 7th/8th October 2012:
146/245/246/247 (Huyton circulars)
The services are now operated for Merseytravel by HTL Buses.
(The routes and the times are unchanged.)
http://merseytravel.gov.uk/pdf/tt_100/14...02012).pdf
192/193/217/227 (Walton or Kirkby - Huyton/Fazakerley, Kirkby or Huyton - Halewood)
Route 192: the Monday to Saturday morning times are changed.
The two buses that currently finish at Kirkby Civic Centre are extended to finish at Kirkby Merseyrail station.
(All other services are unchanged.)
http://merseytravel.gov.uk/pdf/tt_100/19...02012).pdf
410/110 (New Brighton - Woodside/New Brighton - Clatterbridge Hospital)
Route 110: some times are changed. The service is now operated for Merseytravel by Arriva.
Route 410: some Monday to Saturday morning times are changed.
http://merseytravel.gov.uk/pdf/tt_100/11...02012).pdf
883 (Liverpool John Lennon Airport - Huyton Industrial Estate)
Some extra daytime buses are introduced, so the service now runs throughout the daytime.
http://merseytravel.gov.uk/pdf/tt_800/88...02012).pdf
Valid from 15th October 2012:
52/52A (Liverpool - Netherton)
Peoplesbus Route 52A: the times are changed.
(Arriva Routes 52 and 52A are unchanged.)
http://merseytravel.gov.uk/pdf/tt_001/52...02012).pdf
From the above contract changes, route 110 is currently operated by Avon Buses, routes 146/245/246/247 are currently operated by Ace Travel.
our 140 timetable is on merseytravel site now strangely though the 141 is not
Thanks for that, I guess the 141 timetable will be up very soon! The 75 timetable is also up now too as shown below!
75 (Liverpool - Halewood)
The times are changed.
The evening frequency is reduced to 30 minutes.
http://merseytravel.gov.uk/pdf/tt_001/75...02012).pdf
140 (St Helens - Bold Heath or Lingley Green)
The service is now operated without subsidy from Merseytravel.
The times are unchanged.
One more, spotted by Andy Clarke that I'd missed out:
Valid from 1st December 2012:
X5 (Maghull - The Trafford Centre)
This new Saturday service is introduced by Peoplesbus.
Stopping at all bus stops along the route, the service will run on Saturday 01, 08, 15 and 22 December 2012, then the first Saturday of each month.
http://merseytravel.gov.uk/pdf/tt_Alpha/...012%29.pdf
New Maghull Circular times online 2 routes commersial by Ace the other 2 tendered to Cumfybus
Some of these are reposted from yesterday, including the Maghull Circular ones, of which there are two versions up now, one from 7th October, one from 22nd October!
Valid from 6th/7th/8th October 2012:
4/5/231/232/233 (Maghull Circulars)
Route 231: Monday to Friday peak time buses are renumbered 5 and are now operated by ACE Travel, without any subsidy from Merseytravel.
The remaining Route 231 buses are now operated for Merseytravel by Cumfybus. The route is unchanged.
Routes 232 and 233: both services are now operated for Merseytravel by Cumfybus. The routes and times are unchanged.
Route 234: this service is renumbered 4 and is now operated by ACE Travel, without any subsidy from Merseytravel. The route and the times are unchanged.
http://merseytravel.gov.uk/pdf/tt_001/04...02012).pdf
18 (Birkenhead - Moreton)
Route 18 now runs as a separate service, so no longer links with Route 17.
Monday to Friday buses are extended to serve Tarran Way Industrial Estate.
(Routes 17 and 117 are now shown in a separate timetable.)
http://merseytravel.gov.uk/pdf/tt_001/18...02012).pdf
47/47A/48/48A (Liverpool - Southport or Riverside Caravan Park)
ACE Travel Route 47A: the times are changed. Some extra buses are introduced.
(Arriva services are unchanged.)
http://merseytravel.gov.uk/pdf/tt_001/47...02012).pdf
61/161 (Bootle - Aigburth Vale)
ACE Travel Route 61: two extra morning buses are introduced between Broadway/AIntree and Bootle.
(Arriva’s Route 61 and Route 161 are both unchanged.)
http://merseytravel.gov.uk/pdf/tt_001/61...02012).pdf
83 (Birkenhead - West Kirby)
Route 83A is withdrawn, so Hoylake, Meols, Moreton or Upton are no longer served.
Route 83 now runs as a single service between West Kirby, Arrowe Park Hospital and Birkenhead Bus Station.
http://merseytravel.gov.uk/pdf/tt_001/83...02012).pdf
133 (Kirkby - Waterloo)
The service is now operated by Cumfybus, without subsidy from Merseytravel.
http://merseytravel.gov.uk/pdf/tt_100/13...02012).pdf
150/N450 (Liverpool - Birkenhead or New Brighton Night Bus)
Route 50 is withdrawn.
(Routes 150 and N450 are unchanged.)
http://merseytravel.gov.uk/pdf/tt_100/15...02012).pdf
Valid from 20th October 2012:
Routes 4 and 5: the times are changed.
(Routes 231, 232 and 233 are unchanged.)
From the above contract changes, route 133 is currently operated by Stagecoach Merseyside, 231/232/233 are currently operated by Ace Travel.
12/213 (Birkenhead - Arrowe Park Hospital)
Routes 12 and 12A: Route 12A is withdrawn and Route 12 is shortened to run, in both directions, between Birkenhead and Arrowe Park Hospital, so Upton or Noctorum are no longer served.
Route 213: the service is now operated for Merseytravel by Impera.
http://merseytravel.gov.uk/pdf/tt_001/12...02012).pdf
17/17A/117 (West Kirby or Moreton - Clatterbridge Hospital)
Routes 17 and 17A now run as a separate service, so no longer link with Route 18. Buses are extended to run to and from West Kirby via Meols and Hoylake. The times are changed.
(Route 18 is now shown in a separate timetable.)
(Route 117 is unchanged.)
http://merseytravel.gov.uk/pdf/tt_001/17...02012).pdf
93/293 (Birkenhead - Arrowe Park Hospital or West Kirby)
New Monday to Friday daytime Route 93 is introduced by Avon Buses, linking Birkenhead Bus Station with Claughton, Noctorum and Arrowe Park Hospital.
(Route 293 is unchanged.)
http://merseytravel.gov.uk/pdf/tt_001/93...02012).pdf
174/175 (Heswall - Lower Village circular/Heswall - Pensby - Irby circular)
Both services are now operated for Merseytravel by Arriva.
http://merseytravel.gov.uk/pdf/tt_100/17...02012).pdf
471/472 (Liverpool - Birkenhead - Heswall and Barnston)
Route 471: some Arriva Monday to Friday evening mid-journey times are changed.
(All other services and times are changed.)
http://merseytravel.gov.uk/pdf/tt_400/47...02012).pdf
From the above contract changes, routes 174/175 are currently operated by A2B Travel, 213 is also currently operated by A2B Travel.
Are Arriva getting in some small vehicles for this route 174/5 , there is some tight corners and plenty of parked cars making the route a chicane on the section near Irby.
