Current time: 05/11/2026, 02:16 Hello There, Guest! (Login — Register)
Arriva Buses Wales - Wrexham Depot
RE: Arriva Buses Wales - Wrexham Depot
(27/11/2018 20:37)LJ51 DDA Wrote:  I'll try to confirm! first i've heard of it though
edit : Just had confirmation that 687 is not here.
Thanks mate I appreciate that.
Any idea what the new 68 plate clickbuses are at the depot please
Is 4182 still being used as I may nip to Wrexham tomorrow to find it
Was on the 10th January
(15/01/2019 20:29)darylyates17 Wrote:  Is 4182 still being used as I may nip to Wrexham tomorrow to find it
Seen returning from Llangollen yesterday, & on the industrial estate today
I had optare 999 on a 1.last week heading into chester & spotted 998 on the return into wrexham.
Both are really nice inside & seem to be wearing quite well in general.
(16/01/2019 19:07)B193BLG Wrote:  Seen returning from Llangollen yesterday, & on the industrial estate today
I think I’ll deffo come down tommorow since I also need to ride on 689 since it’s swap with 669 do please let me know if you see 4182
(16/01/2019 20:59)darylyates17 Wrote:  I think I’ll deffo come down tommorow since I also need to ride on 689 since it’s swap with 669 do please let me know if you see 4182
4182 will be out usually allocated to 41As if not then it'll run early morning and evening 5Cs and run 41As throughout the day, unless its allocated to 5s
(17/01/2019 05:51)LJ51 DDA Wrote:  4182 will be out usually allocated to 41As if not then it'll run early morning and evening 5Cs and run 41As throughout the day, unless its allocated to 5s
Thanks a lot mate do you know if 689 is out? as I need that one since it’s swap with 669
(17/01/2019 09:14)darylyates17 Wrote:  Thanks a lot mate do you know if 689 is out? as I need that one since it’s swap with 669
It was on loan to Chester if it has returned to Wrexham it's %99 likely its on the road somewhere
