Current time: 06/11/2026, 21:11 Hello There, Guest! (Login — Register)
(26/06/2025 15:43)33109 Wrote:  Enviro200s 37 & 41 from macc depot are apparently being withdrawn imminently & sent off for scrapping.
About time these 09 reg enviros go as they are totally wrecked. My money for replacements is on newer Enviro200s or MMCs.
If the tracking's to be believed 37 last operated a Macclesfield depot route on Saturday and seems to have been put out to cover for 4 on the 84X today. So possibly moved to Crewe ready for withdrawal but then got put out due to a fault on another bus?
Looks like 570 also developed a fault today, while 521, 6007 are showing as working services first thing, but then stopped tracking. If D&G have 4 vehicles failing each morning, I fear some of the withdrawn vehicles might not stay withdrawn for long!
I found it interesting 41 started the day on the 87/88 yesterday but was then swapped with 571 which started the day on the 3/10, so both vehicles remained out but switched routes.
I have seen 117 on the 88 today. It's much quieter than usual. I wonder if the air con system isn't working or if it's been deactivated?
(26/06/2025 16:19)T42 PVM Wrote:  Seems a lot with D&G has been withdrawn in recent weeks, Streetlites 60 & 61, Versa's 25, 157 and 160 along with Solo's 45 and 115
I noticed some vehicles were appearing on the bus times list even though they hadn't tracked in months. I wonder if there's been some update, either with the D&G system or the data feed bus times uses?
With regards 117 the aircon units on its roof don't seem to have worked for years. Certainly the extra vents etc inside never work.
(27/06/2025 09:42)33109 Wrote:  With regards 117 the aircon units on its roof don't seem to have worked for years. Certainly the extra vents etc inside never work.
I've been on it a few times but never on a hot day, so I wasn't sure. The thing that always stood out to me was it made a louder and different sound to the other SRs (which are normally quiet quiet), but when I saw it yesterday it was making the normal SR sound.
Hard to keep track of which vehicles D&G have withdrawn when there's so many double tracking. 165 is on the 3/10s today, not the Congleton locals. While vehicle 130 is on the 130 route. 570 is also tracking as 130 on the 3/10s.
(13/06/2025 17:50)K10K11 Wrote:  https://www.dgbus.co.uk/service-updates/
D&G are claiming that Firdale Road "has not had buses operating along it before" which is not true as the old Davenham, Hartford, Greenbank circular services ran down there, as well as Darwin St and Navigation Rd. There was also the Greenbank Lane circular section.
Google Streetview shows the 1990 style Cheshire Bus stops were previously attached to lampposts along there, but disappeared at some point between 2009 and 2017 - presumably when George Osborne's spending cuts starting having a significant effect on subsided bus services.
[Image: jkZ8Zq1H]
https://ibb.co/jkZ8Zq1H
According to bustimes they've taken on Solo YJ65 EUZ from Holmeswood Coaches.
88 route buses taking an interesting route at the moment during the morning/afternoon due to road closures. Diverting off the B5085 in Mobberley and using the A34, A555 and M56 between Wilmslow and Hale Road.
594 appears to have moved to Macclesfield.
136 has finally got D&G colours after running around in a debranded Ross Travel livery for around 2 years.
It's also been reported they done some swaps so all the Metrocities are in Stoke, including a new one they've just got, with Chaserider no longer having any.
MMC YX19 ONO has entered service on the 31 and 37 routes today. Apparently, previously with Go North East, despite being in plain white.
Also if the bus times tracking is correct Metrocity 144 is on the 89/N1 workings today.
