Current time: 15/10/2026, 18:44 Hello There, Guest! (Login — Register)
Due to the road closure in Chorley D&G had been diverting 88 services back through Morley Green, between Wilmslow and Mobberley. They've now decided to instead divert via Great Warford and Alderley Edge until the closed road reopens. The change is sensible given it means an additional 5 normal stops will be served, rather than missed out. But why didn't they/Cheshire East think of that initially?
It looks like D&G did a vehicle switch on the 87/88 workings earlier, so that a return Knutsford-Altrincham working was cancelled, in favour of retaining the last return 87 working - presumably due a vehicle fault with 122.
I wondered why they didn't use the vehicle off the 89 to plug the gap, and then noticed the layover time on the 89 is now in Northwich, not Knutsford. That begs the question why don't they run the N1 on Saturdays? Surely only a few fares would pay for the cost of the diesel to get up to Greenbank and back. Even if they ran the N1 on Saturdays, there would still be a 35 minute meal break available for the driver, as the 89 doesn't run between 11:35 and 12:40. I suppose the answer is Cheshire West aren't paying them to do it, so they won't.
On a separate point it must be strange at Wythenshawe Interchange today, with just the 130 operating to a 90 minute frequency, and all the other services affected by industrial action. I wonder how many locals even realise the 130 exists?
A new 93A and 93C service has appeared on the D&G website commencing in November. It's a half-hourly Congleton to West Heath to Congleton circular, with 93C going in a clockwise direction and 93A in an anti-clockwise direction. No mention of any change to the 38, which means the Congleton bound 93A looks like it's going to run just behind a 38, while the West Heath bound 93C will run 8 minutes behind a 38.
104 has suffered same fate as 103. Being withdrawn after setting on fire while in service.
I wonder if some issue has been discovered with the 60 reg slimline Solos? It looks like 131 was taken out of service during Monday, with 107 taking over* (a vehicle that used to be in Cheshire but has only moved back from Stoke in the last few days). All three of them sat out Tuesday, with 129 and 130 also sitting out yesterday and today.
While I don't agree with the people who claim Solos aren't ever suitable for longer journeys. I don't think the slimline ones should be used on journeys like the 130/87/88. I think they would be better suited to the 10 route (if they provide sufficient capacity).
41 is still tracking. Although, I wonder if it is still in service. It wasn't too long ago one of the ex-Cardiff MMCs was tracking as 41, while 120 hasn't tracked for a while.
* I have seen a long Enviro 200 with a small D&G logo on the services tracking as 107, so I think the tracking is probably correct. There have been some instances of vehicles at Adderley Green incorrectly tracking on Macclesfield depot services.
There is a Slimline Solo being used on the 88 today and it sounds like it shouldn't be on the road. It's tracking as 129, but 129 is also tracking on the 130 route. The noise it's making sounds like a vehicle that won't start, but it's making it as the bus is moving along!
Just noticed bus times is showing updates from 24 November:
130 service to be routed via Macclesfield station in both directions. Wythenshawe to Manchester Airport section withdrawn.
New 150 service introduced Mon-Fri, interworked with 130 to provide off-peak half-hourly service between Macclesfield and Alderley Park, with peak time extensions to Wilmslow (using a single vehicle to run all journeys).
Edit: Update on D&G site mentions low usage to the airport, and implies the 150 is funded through BSIP.
The Airport has low patronage because the bus is too slow and plods around Heald Green and Wythenshawe first. Then add in the fact the operating hours to the Airport are dismal. Is it any wonder that patronage is low? It was clear Cheshire East were only running the 130 to the Airport as a token thing to keep people quiet, rather than actually wanting to provide a useful service.
In true D&G style, the Airport section is withdrawn, and so they are throwing loads more time into the Wythenshawe to Macclesfield section and now diverting it via Wilmslow Station. Yet again, D&G needlessly slowing down services to such a level that even a nuclear apocalypse wouldn't stop these buses running on time.
(04/11/2025 19:54)iMarkeh Wrote:  The Airport has low patronage because the bus is too slow and plods around Heald Green and Wythenshawe first.
It used to be fast to the airport, and then to Wythenshawe and then Wythenshawe Hospital. Then they revised it to go to Wythenshawe first, then revised again to be a stopping service between Handforth and Wythenshawe.
The only positive is the 130 does use the same stand as the 103 at Wythenshawe Interchange, but doesn't at the airport. So I doubt anyone seeing 130 Macclesfield at a different stand will think it goes to Wythenshawe first.
The 130 serving Wilmslow station might be Cheshire East's idea. They were saying about looking at options for better connections between bus and rail.
