Current time: 20/11/2026, 02:07 Hello There, Guest! (Login — Register)
Northern Rail
RE: Northern Rail
The step boards on the 319's are the same as a 150, not large like the 507's and 508's.
322's used to travel up and down the WCML everyday without an issue and they are basically the same bodyshell.
SD.
RE: Northern Rail
(27/04/2014 17:49)Sprinterdriver Wrote:  The step boards on the 319's are the same as a 150, not large like the 507's and 508's.
SD.
They are not the same bodyshell. 322s share the bodyshell with 320 and 321. The nearest to a 319 is probably the postal 325, which operates mainly on the WCML.
RE: Northern Rail
Yes they are, just different front ends.
SD.
RE: Northern Rail
319361 move apparently back on for tomorrow (we'll see..)
Bit of a tug of war going on between FCC/DFT/Northern..
**EDIT 01.05.14** MOVE CAPED AGAIN!!
RE: Northern Rail
If so, does anyone know timings or headcode?
RE: Northern Rail
I have just read in Todays Railway Uk that the DfT have asked Northern Rail to introduce evening peak ticket restrictions between 16.00 and 18.00 , isnt this going backwards not forwards .
This is a way to try and stifle demand , basically because there is no more diesel multiple units available to increase train lengths.
This looks highly likely to be introduced in September.
RE: Northern Rail
(30/04/2014 12:40)DVG526 Wrote:  319361 move apparently back on for tomorrow (we'll see..)
Has this made its way to Allerton yet?
RE: Northern Rail
(07/05/2014 11:06)MX12CFE Wrote:  Has this made its way to Allerton yet?
All caused by the slow procurement of the Thameslink stock from Siemens , no one wants to be short of stock and im sure the DfT do not really want Northern to be running too many diesels if they can help it under the wires either.
RE: Northern Rail
Hopefully it will be next month, but I can see it being longer unfortunately...
RE: Northern Rail
any news on the 319?
