Current time: 06/11/2026, 03:50 Hello There, Guest! (Login — Register)
High Peak
RE: High Peak
High Peak have had the Notts and Derby branded Centro 791 on loan this week, on transpeak.
RE: High Peak
The latest bus for transpeak is Scania/ Wrightbus Solar YN08 OAJ. It is in transpeak livery.
Double decker 907 has moved on, 906 is expected to replace it, this is apparently due to its seats being more suitable for the long journeys.
RE: High Peak
704 in Transpeak Livery
http://www.flickr.com/photos/guy_arab_uf/7536815256/
i think it looks very smart
As For 906,This has leather seats like the rest of them in huddersfield,think 907 Is the only one without them,so will 907 Be moving to huddersfield to replace 906?
RE: High Peak
High Peak have been posting some changes on their Facebook page and website for 2 September, some of which have been mentioned in the doucments for next week's TfGMC meeting.
*60 - Revised to run weekdays only between Hayfield and Whaley Bridge via New Mills
*62/62A - Most weekday journeys will be curtailed to run between Marple and New Mills only, while Saturday journeys will be withdrawn.
*69 - Schoolday service revised to run between New Mills and Chapel-en-le-Frith school via Hayfield
*69A - Schoolday service revised to run between Gamesley via Chapel-en-le-Frith school via Simmondley and Glossop
*76 - Times changed with route revised to serve Buxton Market place, Sherwood Road and Bath Road
*202 - Times changed
*389 - Times changed
*394 - Following journeys to be withdrawn: 6.45am weekdays and 8.23am & 5.20pm Saturdays from Glossop, 5.20pm Saturdays and 6.20pm Mon-Sat from Stepping Hill.
http://www.highpeakbuses.com/Pages/Lates...lNews.aspx
RE: High Peak
The 60 might actually be two co-ordinated overlapping services with the same number, as Derbyshire CC's timetable site says "additional Hayfield - Whaley Bridge journeys introduced"
RE: High Peak
(26/07/2012 20:38)Nicholas Wrote:  The 60 might actually be two co-ordinated overlapping services with the same number, as Derbyshire CC's timetable site says "additional Hayfield - Whaley Bridge journeys introduced"
High Peak website only has the Hayfield-Whaley Bridge timetable but the website does say 'certain journeys will run through from Macclesfield', so may be possible that will be the case.
http://www.highpeakbuses.com/utilities/p...huttle.pdf
RE: High Peak
I took advantage of 'The Boss' wanting to visit a shop 'over the hill' in Buxton at today to check-out the High Peak operations.
The former Bowers yard off Hadfield Road East is very much still in use; Photo Here
The nearby 'shed' and yard off Sheffield Road also appears to still be in use for major repairs with the cannibalised remains of two withdrawn buses on site;
370 - X942 NUB
436 - R154 RAL
Did either of these see service with the High Peak operation or were they withdrawn prior to its commencement?
By contract the former Trent depot at Dove Holes on the A6 only had a couple of Scania/Wright Solar's present along with the recently transferred Scania/East Lancs double decker 904 - YN07 LHT
Finally, High Peak were also using the coach park at Spring Gardens in Buxton for buses on lay-over between turns.
HTIOI
Nick
RE: High Peak
High Peak/Bowers have been using the coach park at Spring Gardens (if its the one I think you mean) for a while now and its normally buses of the 42/442 Ashbournes that can be found parked up there in between journeys
I know we can only dream but I'd love to see one of those Olympus's out on a 199 sometime
RE: High Peak
(16/08/2012 22:27)M60lad Wrote:  High Peak/Bowers have been using the coach park at Spring Gardens (if its the one I think you mean) for a while now and its normally buses of the 42/442 Ashbournes that can be found parked up there in between journeys
I suspect it will only be a matter of time - but I'm bound to be at the other end of the country that day! Undecided
RE: High Peak
Ex High Peak SN03DZY has turned up with Harris bus Burnley still with full connect 19 branding http://flic.kr/p/dczTwQ
