Current time: 06/11/2026, 06:32 Hello There, Guest! (Login — Register)
(10/02/2017 13:10)wirralbus Wrote:  Wouldnt it be better for Arriva to go into emergency mode and just seperate the 432/3 from the 437 once they have enough vehicles to provide a service on both routes.
That's a good idea; I wonder if the controllers have thought of that? I suppose the fact that each driver has a specific running board with a specific timetable is a factor. Also, in this day and age, failure to operate specific services without prior notice would probably fall foul of the TC's.
I think the days of being able to run an ad hoc bus service are well gone, irrespective of the circumstances. Back in the day, it was not uncommon for an inspector to simply instruct a driver to run a return journey on a route that was experiencing problems.
Is the 437 going via Arrowe Park and Noctorum or via Moreton and the Beechwood ?
View my flickr http://m.flickr.com/#/photos/104753198@N08/ my flickr account.
(10/02/2017 13:28)Barney Wrote:  That's a good idea; I wonder if the controllers have thought of that? I suppose the fact that each driver has a specific running board with a specific timetable is a factor. Also, in this day and age, failure to operate specific services without prior notice would probably fall foul of the TC's.
The problems with interworking services is you have the 437 causing problems , really the 432/3 is a standalone service and the service shouldnt be affected at all , but is being affected though.
(10/02/2017 13:28)WAITING FOR THE 437 Wrote:  Is the 437 going via Arrowe Park and Noctorum or via Moreton and the Beechwood ?
437 is going via Beechwood and Moreton
Follow me on flickr
418/419 is also going via Moreton, not sure if they're doing a double run through Beachwood though.
Latest is M53 now closed until after rush hour, http://www.liverpoolecho.co.uk/news/live...s-12584227
Why does it take so long to investigate one body, you'd think it'd been a pile up?
Because they think theres suspicious circumstances it said before as after all someone as lost there life and there not 100% sure how.
(10/02/2017 16:05)motormayhem1 Wrote:  Because they think theres suspicious circumstances it said before as after all someone as lost there life and there not 100% sure how.
Fair point
Going to be mad in the peak around that area, just seen an 419, 14.45 departure from Woodside on Arriva livemap 68 minutes late.
I've been thinking when something like this happens, whether Arriva should do an emergency timetable, by splitting the 437 at Claughton to operate in 2 sections with through tickets allowed?
(10/02/2017 15:38)MTL0201 Wrote:  418/419 is also going via Moreton, not sure if they're doing a double run through Beachwood though.
418/419 were going through Moreton/Bidston Tesco and missing out Beechwood, passengers wanting here had to use the 492/5. A 419 even used the M53 at Moreton Spur instead of going through Moreton too as it was gridlocked, It ended up on time and in front on the 418 that was supposed to be 30 minutes in front running over 40 minutes late.
(10/02/2017 21:51)N301 CKB Wrote:  418/419 were going through Moreton/Bidston Tesco and missing out Beechwood, passengers wanting here had to use the 492/5. A 419 even used the M53 at Moreton Spur instead of going through Moreton too as it was gridlocked, It ended up on time and in front on the 418 that was supposed to be 30 minutes in front running over 40 minutes late.
Did the driver use his own initiative or was he instructed to do so using the two-way radio system?
User(s) browsing this thread: 39 Guest(s)
