Current time: 04/11/2026, 14:14 Hello There, Guest! (Login — Register)
Does anyone know if the white Evo’s are entering back into service soon?
Also, I’ve been travelling on the newly-formed 82A. While I’m glad it’s legacy is revived and, for the most part, it is a good service, there are some issues I’d like to see ironed out by the next timetable change.
Firstly, I think this time around, it mimics the 82 route too much. The route now avoids the Estuary Business Park and uses Park Road instead of Riverside Drive. There is already a very sufficient service level in the Park Road area, so in my opinion, routing the bus this way seems pointless.
I’d like to see the 82A reverted to run via the Estuary Business Park and Riverside Drive, as per the pre-Sept 2018 route. Many of the previous 82A/500 users saw the service as a great direct route to access work and other facilities in the Otterspool and Brunswick areas. People now need to change at John Lennon Airport for the 500 and wait 15 minutes. The traffic also flows much better this way, as from Sefton Street up until the junction at Jericho Lane and Aigburth Road, there are no traffic lights (not including the pedestrian crossings, which are used infrequently). This would ensure reliability and maintain a good service along this stretch of road. This could also mean journey times on the 500 could be shorter, as if the 82A serves these stops, the 500 will not need to. It would only need to serve all stops outside of the 82A’s start and finish times.
This brings me into my second point, and one that I know is being quite heavily criticised at the moment. The 82A currently starts too late and finishes too early. I’d understand the decision if there were alternative bus services at all of the communities the 82A passes through, but unfortunately this is not the case. The likes of Hale, Ditton and Coronation Drive are served only by a few services (only the 82A in Hale’s case) that already finish early, so these service cuts off the back of the 500 are a further blow to the areas that see this service as near enough a lifeline. I know there are quite a lot of residents in these areas that do not drive, and for those with early-starting/late-finishing jobs, this may force them to travel by car, have to change their shifts or even quit their job.
If Arriva deems a timetable extension ‘unsustainable’ then I think the local authorities could intervene, like Merseytravel did with the 61 (extending the service into Liverpool from Broad Green). The current timetable is just not fit-for-purpose in its current form and seriously needs to be reconsidered.
2508 is the latest arrival here for P&P cover
Full Fleet update here
Out: 2489, 2491, 2493, 2494, 2497, 2505, 2616, 2617, 7923, 7924, 7932
In: 2508, 2510, 2643, 2665, 2666, 2667, 2698, 2700, 3000, 3039, 3040, 3041, 3042, 3043, 3044, 3046
3136 has gone in for P&P
(08/09/2020 20:58)LT10 Wrote:  Full Fleet update here
I expect 2493 is 3024's replacement!
SK15 GZG
2542 is withdrawn for scrap
Would anyone happen to know what’s happening with 5004? Thanks
The 82A timetable changes from 4th October. Additional journeys operate on weekdays between Murdishaw/Halton Hospital and John Lennon Airport (connections to City Centre via 500).
https://merseytravel.adidocdn.dev/timeta...4Oct20.pdf
These short journeys will operate in both directions, extending operation times early in the morning and late at night.
Halton Hospital - JLA
Dep 0520, 0550, 0620
Arr 0627, 0657, 0727
Murdishaw - JLA
Dep 1957, 2057, 2157
Arr 2112, 2212, 2312
JLA - Murdishaw
Dep 0631, 0701, 0731, 2316
Arr 0746, 0816, 0846, 0029
Hopefully this sits well with residents and hoping to see additional weekend services soon!
(30/09/2020 16:15)Liamkennedy2231 Wrote:  The 82A timetable changes from 4th October. Additional journeys operate on weekdays between Murdishaw/Halton Hospital and John Lennon Airport (connections to City Centre via 500).
Murdishaw - JLA
JLA - Murdishaw
Bit of a shame this wasn't picked up on prior to the last timetable release but fair play to Arriva, at least they have sorted it out. Much better timetables though these and I hope the trips are viable.
(23/09/2020 19:39)MX12 KVM Wrote:  Would anyone happen to know what’s happening with 5004? Thanks
It as been back in service for a while and in the new livery
