Current time: 15/10/2026, 16:23 Hello There, Guest! (Login — Register)
Selwyns
RE: Selwyns
(17/12/2018 17:15)knutstransport Wrote:  It might not warrant a double decker but if the operator has some sat around spare and there's a break down then it makes their job easier if a double decker can be used.
Only if it worked the 392. The routes interwork at Stockport, so it would need to substituted, before doing a 391 which passes under the Grimshaw Lane, Bollington 11' bridge.
RE: Selwyns
Exactly so it'd be a bit of a ballache to swap buses around on every trip.
Besides there's nowhere near enough passengers to fill a decker anyway.
RE: Selwyns
(18/12/2018 15:54)33109 Wrote:  Exactly so it'd be a bit of a ballache to swap buses around on every trip.
I was referring to an emergency situation where the intended bus can't be used and a decker is available. Howards used a decker on the 27 Macclesfield-Knutsford on one occasion when the usual Enviro was unavailable but it doesn't mean the route warranted a decker, it was just what they had spare.
RE: Selwyns
(19/12/2018 19:01)knutstransport Wrote:  I was referring to an emergency situation where the intended bus can't be used and a decker is available. Howards used a decker on the 27 Macclesfield-Knutsford on one occasion when the usual Enviro was unavailable but it doesn't mean the route warranted a decker, it was just what they had spare.
I cant see that happening in any situation as notwithstanding the low bridge on the 391, overhanging very low trees would probably preclude it anyway. As for the 27, that particular working was only two round trips and was driven very, very cautiously on the Chelford - Knutsford section to avoid damage by trees. Was a nice run on a decker though.
RE: Selwyns
(16/12/2018 12:07)Mayneway Wrote:  having said that they wer using MMC Enviro200 SK68LZO last week, devoid of any fleet names its hard to say whether it's been acquired or is on loan.
SK68LZO now has Fleetnames applied.
RE: Selwyns
(21/12/2018 11:09)dca529x Wrote:  I cant see that happening in any situation as notwithstanding the low bridge on the 391, overhanging very low trees would probably preclude it anyway. As for the 27, that particular working was only two round trips and was driven very, very cautiously on the Chelford - Knutsford section today avoid damage by trees. Was a nice run on a decker though.
GHA also used deckers and coaches on the 27 more than one occasion when the deadline for inaccessible single decker buses had past with them operating the 27 commercially so not having a contract requiring a step free vehicle, unlike on routes like the 19, 42, 88 and 200. Although, unlike Howard's GHA didn't run every 27 service via Over Peover.
RE: Selwyns
Couple of issues this week with the 391/392. Traffic has been a nightmare this week with timekeeping being quite tricky.
Also solo YJ12 GZH broke down on thursday with a slipping gearbox. Replaced by YJ12 GZG & eventually got into macc 43 mins late according to the ticketer machine.
RE: Selwyns
(13/01/2019 11:39)33109 Wrote:  Couple of issues this week with the 391/392. Traffic has been a nightmare this week with timekeeping being quite tricky.
They have really ended up with a shocking batch of Solos. The amount of lost time/journeys since they took over these tenders (including the 129) must be huge. Presumably the MMC Enviro200 has been acquired to try and resolve things in North Manchester but it sounds like things are just as bad Stockport end.
RE: Selwyns
(13/01/2019 11:43)Mayneway Wrote:  They have really ended up with a shocking batch of Solos. The amount of lost time/journeys since they took over these tenders (including the 129) must be huge. Presumably the MMC Enviro200 has been acquired to try and resolve things in North Manchester but it sounds like things are just as bad Stockport end.
A lot of operators seem to have replaced old style Solos with newer Solo SRs, do the old style Solos in general have a shorter life than some operators would like?
When GHA were around the former Cheshire County Council 52 and 54 reg Solos weren't that reliable and the one they acquired which used to be used by Tomlinson Travel was in such a bad state I don't think it ever got used by GHA.
RE: Selwyns
Pass but the ones they've got.now are the small versions with a single leaf door.
They only take about 25 people tops which is a tight squeeze if anyone gets on with a shopping trolley or a pram as the door folds inwards where the cab is.
