Current time: 16/10/2026, 03:43 Hello There, Guest! (Login — Register)
The Centros arrived before the first Pulsar which was followed by more Cadets/Commanders before it became all Pulsars. If anything the Centros would have been Cadets as aren't they on the shorter SB120 chassis?
Are the palatime II's still hanging on? there's been no mention for a week or two.
Thanks in advance.
ANW 2283
Previously marcus T
Darting across the NW and Midlands...Smile
Starting to put a moves book together...
http://www.ipernity.com/blog/bontybermo
3311/34 R311/34 WVR Seem to be the only one's out - Not seen 330 and 331..:/ The end of an Era is soon!
(06/05/2013 19:48)Marshall Capital SLF Wrote:  3311/34 R311/34 WVR Seem to be the only one's out - Not seen 330 and 331..:/ The end of an Era is soon!
Thanks...Still require 3311...Not sure if I'll make it back before it goes...Sad
ANW 2283
Previously marcus T
3334 Out for the morning - Although it was sent to the depot at 8AM as it wouldn't go above 20MPH Or into 2nd Gear, 3311 Was out though - On the duty that would of been 09:25 84 Off Chester
3334 Out again today - They seem too go out when short.
A little bit late but I've only recently been activated...
3334 was out on Friday..The 1235 from Sandbach - Northwich (from Crewe), the return short service to Sandbach and then the 1505 from Sandbach - Northwich. Also out were 4143(#37),4096(#84 shorts),4099(31A),4141(#37)...
Regards,
Ybhhs...
Do Winsford Depot still run deckers on 31/A Northwich-Crewe service or are these services mainly in the hands of the Centos now, I know these services are mainly Centros but I know the odd duty used to have a decker on it and wondered whether it still does
Tell me this why are Females at Arriva Macclesfield so nasty. I took a picture S242JUA comming out of Macclesfield bus station then get the v's so I had enough and gave her it back then the bus stopped and I could see her getting off so I legged it. She does it all the time even get yelled at by her. anyone ever had this issue or similar ones with her
http://busncoachfleetlists.comli.com/ The new fleetlist site containing lots of new things
Currently the Macclesfield photographer for anything Arriva Macclesfield and Winsford, Arriva Wythenshawe, High Peaks, Aimees, Holmeswood, GHA and anything else I photograph
My blog http://maccbusspotter.blogspot.co.uk/
Why run away? If she confronts you, just tell her you'll be submitting the photo to the depot for their consideration.
A very sweeping, and potentially unfair, comment regarding the female drivers based at Macclesfield mind.
