Current time: 04/11/2026, 08:58 Hello There, Guest! (Login — Register)
(25/04/2023 20:49)North West Bus Spotter Wrote:  The MX14s are in fact coming here, they're just being stored at Bootle (3159) and Green Lane (3160 and 3161) until the Rail Replacements are done
They're not being stored. They're to cover 'deckers on rail replacements.
Information RE: Arriva North West - Runcorn Depot
(07/03/2023 19:23)Valandil Wrote:  26s, 27s and 61 are still around in some form or another, as well as whatever remains of the 62 after the next round of cuts to the service.
I guess you could count the 200 too.
The Route 200 is Ran by Arriva, But is operated on behalf of Halton Borough Council
So this route is not going anywhere
Formally Bobbi_1042_Runcorn
(28/04/2023 02:20)Busway_Bob Wrote:  The Route 200 is Ran by Arriva, But is operated on behalf of Halton Borough Council
This would be correct, the 200 used to be ran by Halton Transport on behalf of the Halton Borough Council but is now ran by Arriva on behalf of the Halton Borough Council. What I'm wondering is will Arriva shove our soon to be new vehicles (3159, 3160 and 3161) on the 200?
(28/04/2023 07:18)North West Bus Spotter Wrote:  This would be correct, the 200 used to be ran by Halton Transport on behalf of the Halton Borough Council but is now ran by Arriva on behalf of the Halton Borough Council. What I'm wondering is will Arriva shove our soon to be new vehicles (3159, 3160 and 3161) on the 200?
Think you will find thetge tender is for a small bus always as been when it was first started it was run by Arriva using one of the short Ex MTL Darts in a special livery only run from Mursdishaw at the time Runcorn had 807 808 plus 809 two were used the the 3A&3C
(28/04/2023 09:10)trixmax2000 Wrote:  Think you will find thetge tender is for a small bus always as been when it was first started it was run by Arriva using one of the short Ex MTL Darts in a special livery only run from Mursdishaw at the time Runcorn had 807 808 plus 809 two were used the the 3A&3C
Although the tender is designed to use a small bus the actual wording will be on the lines of “no fewer than XX seats”. Arriva have and do use Pulsars on the service, the most obvious example being the peak time extras.
(28/04/2023 10:36)Raawwwrrr! Wrote:  Although the tender is designed to use a small bus the actual wording will be on the lines of “no fewer than XX seats”. Arriva have and do use Pulsars on the service, the most obvious example being the peak time extras.
Living in Runcorn, I can confirm this is true, however, 674 is going to Disposal so I wonder if we will get a MX12 Solo SR or maybe a Strata. We still need a replacement for 2669 as well as 3159, 3160 and 3161 are due to replace 2698, 2699 and 2700.
(28/04/2023 13:05)North West Bus Spotter Wrote:  Living in Runcorn, I can confirm this is true, however, 674 is going to Disposal so I wonder if we will get a MX12 Solo SR or maybe a Strata. We still need a replacement for 2669 as well as 3159, 3160 and 3161 are due to replace 2698, 2699 and 2700.
Don’t forget that the PVR has dropped by 2 with the 62 being withdrawn so not all will need to be replaced
Youtube Channel:
(28/04/2023 13:31)Y458 KNF Wrote:  Don’t forget that the PVR has dropped by 2 with the 62 being withdrawn so not all will need to be replaced
Fair point but if they want to keep a smal bus on the 200, they would have to get a new one instead of shoving Pulsars on it
(28/04/2023 13:52)North West Bus Spotter Wrote:  Fair point but if they want to keep a smal bus on the 200, they would have to get a new one instead of shoving Pulsars on it
Think an SR will end up at Runcorn seems all the Classic Solos are going to Wales
Youtube Channel:
3160 is now at the depot, saw it parked up behind another Pulsar 2
Also, can someone provide an update on 3089? Hasn't been in service for a month
