Current time: 16/10/2026, 03:50 Hello There, Guest! (Login — Register)
St Helens Area Bus Network Changes - April 2023
RE: St Helens Area Bus Network Changes - April 2023
They still haven't corrected the 29 timetable though, apparently the bus leaves Rainhill and St Helens at the same time on two journeys.
They've changed the 28. Basically the route has been changed between St Helens & Laffak completely. The service will no longer extend beyond St Helens to the Hospital & increased to every 30 minutes.
What's everybody's views about this.
https://merseytravel.adidocdn.dev/timeta...6Apr23.pdf
Also does anybody know if there are anymore changes to services that haven't been listed on Merseytravel's website?
According to Notices & Proceedings, there are also timetable changes on 31 & 34/34A.
New timetable for the 34 is on the TFGM website.
(30/03/2023 04:53)St Helens Rider Wrote:  According to Notices & Proceedings, there are also timetable changes on 31 & 34/34A.
What r the changes to them?
(01/04/2023 15:45)Merseysidebusenthusiast Wrote:  What r the changes to them?
Not sure as they have only appeared in Notices & Proceedings, not listed yet on Merseytravel's website.
CHANGES TO 31 & 34/34A
31: Stop changed in St Helens from stop 1 to stop 3.
34/34A: Times have changed https://merseytravel.adidocdn.dev/timeta...6Apr23.pdf
(07/04/2023 08:13)Merseysidebusenthusiast Wrote:  CHANGES TO 31 & 34/34A
So 31 now going from the same stand as the 329.
(07/04/2023 12:24)St Helens Rider Wrote:  So 31 now going from the same stand as the 329.
Ye I dont know why there changing this because it was fine at Stand 1.
(07/04/2023 12:48)Merseysidebusenthusiast Wrote:  Ye I dont know why there changing this because it was fine at Stand 1.
Think some 31's clash with the 34/34A timetable wise. Certainly the case every hour at xx40 and there may be other instances.
