Current time: 29/11/2026, 18:04 Hello There, Guest! (Login — Register)
RE: Stagecoach Manchester
10042-51, probably replacing a selection of the oldest Enviro400s post-Olympics.
I've heard the MANs could be leaving after the Olympics, so they could be replacing those. Perhaps the 15 would be converted to full-time double-deck operation as a result.
What would go on the 171s then?
is staff bus 49752 still in the fleet as it is not on fleet list dated 4/12
Was certainly around at the end of April...
http://www.flickr.com/photos/psbusdriver/7110998327/
(09/06/2012 20:30)R971XVM Wrote:  What would go on the 171s then?
I've got no idea! lol Just something I was told.
TBH, Solos would probably suffice for that route anyway. The only routes that are routinely allocated MANs are the 15 and 171. I'm not aware of any school services that are allocated MANs.
Sharston has around 5 for use on the 84 (although often at least one board is Enviro400 allocated with one appearing on the 42A).
It is Ashton and in particular Stockport that has the largest amount of MANs, and that would involve a large order to replace them, even if it is just the S to X reg examples.
The merc minibus Is in the far arch right at the back of Hyde rd
(10/06/2012 10:14)StageStig Wrote:  The merc minibus Is in the far arch right at the back of Hyde rd
which one 40660 or 41166
40660 is still in daily use at AZ so carnt be that one!!
41166 I think is the one under the arches... that'd be enough for the 171s, even a Primo is overkill. (Waits for someone to tell me capacities are the same)
User(s) browsing this thread: 27 Guest(s)
