Current time: 07/11/2026, 18:34 Hello There, Guest! (Login — Register)
(23/06/2016 14:21)T42 PVM:569 Wrote:  Overhead Wires around St Helens are playing up meaning some Trains are cancelled and others are delayed
Euxton Jn is the exact area of the overhead line problems
How come thats affecting the Wigan stoppers?
Because for a while the power was off in the Wigan station area hence a service terminated at Bryn and St Helens Central
(23/06/2016 14:32)Gordon V Wrote:  Because for a while the power was off in the Wigan station area hence a service terminated at Bryn and St Helens Central
They do a blanket isolation to start off with and then slowly restore power bit by bit until they find the area that is causing the problems
(23/06/2016 15:04)wirralbus Wrote:  They do a blanket isolation to start off with and then slowly restore power bit by bit until they find the area that is causing the problems
Well in this case the power was affected over a wider area than might normally have been expected but that's not always the case
Things seem to be ok again now thankfully
(23/06/2016 15:57)T42 PVM Wrote:  Things seem to be ok again now thankfully
Yes full repairs at the weekend
Services that previously terminated at Appleby from Leeds will now continue on to Armathwaite , this alteration has been in place since 27th June.
The service between Appleby and Armathwaite and vice versa will operate on the Carlisle bound line only .
The train about to leave Lime st for Manchester Vic has Thomas the Tank on loud speaker... LOL
Edit: its for Warrington Bank Quay and not Victoria. Is this a test?
(06/07/2016 14:44)RedPanda Wrote:  The train about to leave Lime st for Manchester Vic has Thomas the Tank on loud speaker... LOL
Been discussed on another forum. It has that tune programmed in to prove the CIS is working before any routes have been programmed in but like everything else on the 319s the CIS are faulty (or the rail staff have been playing with them) so they are playing out that tune instead of making announcements.
