Current time: 19/11/2026, 01:07 Hello There, Guest! (Login — Register)
(01/02/2026 12:19)Raawwwrrr! Wrote:  In addition there is also the 483/484 which will cover this section
Which is every 60 minutes in the proposals, they need to be at least every 30 minutes, the old 83/83A was every 30 minutes, if that's the route the 483/484 are taking.
(01/02/2026 13:06)MTL0201 Wrote:  Which is every 60 minutes in the proposals, they need to be at least every 30 minutes, the old 83/83A was every 30 minutes, if that's the route the 483/484 are taking.
I can’t personally say that Moreton to West Kirby requires more than 3 buses per hour, the current buses usually pass by empty bus stops
(29/01/2026 23:03)gka472l Wrote:  Full list of proposed Wirral routes below....
I wonder whether Merseytravel day tickets will be valid on these services run under permit to them?
One thing i will say, when the Bee Network became active they kept what they already had & reviewed the network afterwards, & most of the changes have been renumberings, that is what should have happened here, kept what they have & do network review at a later date not what feels like both at the same time.
(02/02/2026 02:41)MTL0201 Wrote:  One thing i will say, when the Bee Network became active they kept what they already had & reviewed the network afterwards
Not quite. The Bee Network routes were drawn up before Little Gem collapsed, and they didn't initially include any provision for Warrington's Own Buses operating subsided services in Greater Manchester, or the Bee Network extending out to Warrington. That meant the X5 Warrington to Manchester Airport was split into three routes!
One thing I have noticed and not sure if it's been brought up the historic 129 will be no more once franchising happens it's not even on the list
Sure I read something a while ago saying that it has to run due to the nature of the route
This begs the question why wasn't it withdrawn years ago as it's a pointless 1 trip once a week route
from memory no one ever gets it as loads of operators have operated it since first (Ace Travel, Impera, Stagecoach, Eazibus, A2B and I'm sure Cumfybus did briefly at one stage)
Although it hasn't run quite as long as the 129, similarly there is no mention of the 111 in St Helens. Previously this was an hourly service that was withdrawn bar the one journey in the review of 2016 (it currently works onto the 137).
FYI - Operators of the 129 since 1986 have been Merseybus, Crosville, First, ACE Travel, Eazibus, A2B Travel, Stagecoach and back to A2B Travel who operate it at the moment. The 129 has picked up passengers at times, especially when it gets in front of a 3A/423.
The 129 should have been withdrawn years ago, i've never seen anyone on it, & i live near midway through the route, it's only 1 journey each way Sunday afternoon, & you have 35 minutes at Frankby, that most visitors would either drive or get a bus/train & change to the 437 [or maybe 22 Monday to Saturday if changing at West Kirby], i don't get the reason it keeps running.
(04/02/2026 00:55)MTL0201 Wrote:  The 129 should have been withdrawn years ago, i've never seen anyone on it, & i live near midway through the route, it's only 1 journey each way Sunday afternoon, & you have 35 minutes at Frankby, that most visitors would either drive or get a bus/train & change to the 437 [or maybe 22 Monday to Saturday if changing at West Kirby], i don't get the reason it keeps running.
There must have been a historical reason for the service in the first place .
Even if it is not in the franchise agreement there will probably be complaints if it is removed , the route should go out for consultation before removal
