Current time: 04/11/2026, 10:13 Hello There, Guest! (Login — Register)
(18/06/2014 17:06)turbo777 Wrote:  Is there a East Lancs Myllennium on the 32A?
That will be 2451 which is here at present.
(18/06/2014 17:09)St Helens Rider Wrote:  That will be 2451 which is here at present.
Yeah it was 2451 as it went out on the afternoon peak hour run out on the 32A.
Thanks I thought I was seeing things. What condition is it in?
2349 was seen on the 10A this morning, amd again in mid-afternoon.
(18/06/2014 05:21)motormayhem1 Wrote:  2426 as arrived back at st helens along with 3068
It's safe to say that is one deeply unpleasant bus. Many Birkenhead drivers refused it over time. Speke gave it to Runcorn, who don't like to use it. Good luck with it Wink
Daniel Christopher.
Sounds like standard Arriva practice to send all the rubbish to St Helens - you only have to catch some of the Darts (2242, 2248 & 2251 spring to mind).
Well bit of a shock but 2451 is going out on the 37/38 and looks to be on the late bpard for the 356.
(19/06/2014 22:22)St Helens Rider Wrote:  Sounds like standard Arriva practice to send all the rubbish to St Helens - you only have to catch some of the Darts (2242, 2248 & 2251 spring to mind).
Didn't realise that you had 2248, rode it when at Bootle, truly shocking bus in every way.
(20/06/2014 05:21)MPTE1955 Wrote:  Didn't realise that you had 2248, rode it when at Bootle, truly shocking bus in every way.
Apologies MPTE1955, it was a typo. I meant 2249 which is probably just as bad.
(20/06/2014 05:08)motormayhem1 Wrote:  Well bit of a shock but 2451 is going out on the 37/38 and looks to be on the late bpard for the 356.
I was shocked to see this travelling down Rainford By Pass this morning. It wasn't on the 356 late board tho
User(s) browsing this thread: 95 Guest(s)
