Current time: 06/11/2026, 10:35 Hello There, Guest! (Login — Register)
(04/04/2024 11:00)lcm453 Wrote:  Once every hour there's a 38 and 407 running together between St James's church and West Kirby. Bus companies are not supposed to collude with each other but surely anyone with a brain at either company can eliminate this wasteful duplication.
This is a result of one service running every 30 mins , and the other every 20 mins , you will get at some point one of the journeys running close to each other , be aware the 38 does detour around the sandbrook .
(17/06/2024 12:25)wirralbus Wrote:  This is a result of one service running every 30 mins , and the other every 20 mins , you will get at some point one of the journeys running close to each other , be aware the 38 does detour around the sandbrook .
The 407 also diverts via Millhouse Lane.
Also look at services between Birkenhead Bus Station and Woodchurch where Arriva's 413/414/423/471/472 and Stagecoach's 41/42/471/472 also follow each other.
(17/06/2024 23:37)moreton407 Wrote:  The 407 also diverts via Millhouse Lane.
You have to look at the Woodchurch Road services in isolation as such the 471/2 run to a combined timetable so they aint running on each others toes
No matter how you timetable Woodchurch Road services there will always be a bus ahead or behind , in the future it will be managing that gap that will become important for the LCR .
With the 407 doing one estate and the 38 doing the other there is no real advantage for both routes , unless the 407 goes half hourly as well , but that wont happen because of the interaction with the 471/2 in Liverpool .
6005 has arrived back here from P&P and 6003 has gone to St Helens
Does anyone know what's up with 4515 ,it hasn't been. out for months, thanks in advance
(22/07/2024 11:47)bus401 Wrote:  Does anyone know what's up with 4515 ,it hasn't been. out for months, thanks in advance
Just seen it now on test.
2921 is here on 414.
4515 is back in service.
I seen in Liscard that the 2921 CX58 FZB VDL SB200 Wright Pulsar has now been fitted with White LED destination blinds quiet weird to see to be honest
(30/07/2024 11:59)Merseysidebusenthusiast Wrote:  I seen in Liscard that the 2921 CX58 FZB VDL SB200 Wright Pulsar has now been fitted with White LED destination blinds quiet weird to see to be honest
It's the way it's done now by Hanover as they no longer produce orange LED display units, 6000 had its front display replaced towards the end of last year with one from a withdrawn Bolton Pulsar.
Former First Leeds B5LH 39232 has turned up at Laird Street, reported to be for spares for Arriva's own B5LH. First Leeds has withdrawn most, if not all theirs recently.....
