Current time: 06/11/2026, 11:46 Hello There, Guest! (Login — Register)
(26/03/2026 14:31)Y458 KNF Wrote:  6026-28 are for the 201/211 at Green Lane Southport have 6029 & 6030 of the ex Rotala examples. Speke and Southport have the ex dealer ones.
6026, 6027 and 6028 are now in service. The ex Click Sprinters now withdrawn. Pulsar 3015 will also be the backup for maintenance cover. Any bus can be used on 201 and Clatterbridge but only the Streetlites can be used on the 211.
I was on the 487 from Liverpool to Neston the other day & the bus was standing room only after leaving Birkenhead Town Centre [this was the 12pm service from Liverpool], that left me thinking, should this route be rerouted in Neston so deckers can be allocated to it?
(17/04/2026 23:14)MTL0201 Wrote:  I was on the 487 from Liverpool to Neston the other day & the bus was standing room only after leaving Birkenhead Town Centre [this was the 12pm service from Liverpool], that left me thinking, should this route be rerouted in Neston so deckers can be allocated to it?
This has been a long standing (pardon the pun) issue with the 487 for a while now, particularly in the evening as it’s the only bus serving Higher Bebington, it’s also timed at the same time as the 38A so sometimes gets all the load for Higher Tranmere as well. The route needs reviewing, absolutely no need to be serving Little Neston/Ness Gardens every 30 mins with the bus often running empty or very lightly loaded beyond the Three Stags. An alternative option could be to swap route with the 464 going via Church Road instead to take some pressure off.
(18/04/2026 12:54)DVG526 Wrote:  This has been a long standing (pardon the pun) issue with the 487 for a while now, particularly in the evening as it’s the only bus serving Higher Bebington, it’s also timed at the same time as the 38A so sometimes gets all the load for Higher Tranmere as well. The route needs reviewing, absolutely no need to be serving Little Neston/Ness Gardens every 30 mins with the bus often running empty or very lightly loaded beyond the Three Stags. An alternative option could be to swap route with the 464 going via Church Road instead to take some pressure off.
Back in the day Crosville used deckers on the 87/88 but they were low height deckers, the route passed to Merseybus who extended the 10A to Parkgate as 10B, but that went via Hinderton Road rather than Liverpool Road so standard deckers could be used.
The 88 became 488 continued to Ness Gardens but Merseybus didn't have low height deckers for the 488 so used Nationals for a time then Merseybus bought a batch of Ikarus Citibuses for the 488.
2752 has returned to service after it's RTA
4494 is here currently on 407.
(24/07/2026 06:50)N304CLV Wrote:  4494 is here currently on 407.
4858 is also here.
From documents from LCHR earlier this year there was a mention of compulsory purchase. Do forum members have any information regarding this and in particular will there be any expansion of the premises in Laird Street?
(26/07/2026 14:44)lcm453 Wrote:  From documents from LCHR earlier this year there was a mention of compulsory purchase. Do forum members have any information regarding this and in particular will there be any expansion of the premises in Laird Street?
If I remember correctly? The purchase order was regarding this space, next to the depot.
Attached File(s) Thumbnail(s)
Been hating Urban 90's since 2001Dodgy
(25/07/2026 20:07)N304CLV Wrote:  4858 is also here.
They are to replace 4851/2 which have been withdrawn
User(s) browsing this thread: 52 Guest(s)
