Current time: 04/11/2026, 01:27 Hello There, Guest! (Login — Register)
The Olympian had it's half shafts removed and the radiator grille off at the front so I assume it's been towed in
(30/08/2015 18:27)Scania1996 Wrote:  The Olympian had it's half shafts removed and the radiator grille off at the front so I assume it's been towed in
That sounds an expensive repair. Could be the end.
(30/08/2015 11:49)R879 HRF Wrote:  17502 is on the 15 in New Brighton
Yesterday Olympian 14166 were at New Brighton seem fine, I last saw before lunch time but after that I don't know what happen but I noticed rear near side wheel have oil messy, may had been repaired before back sea front service.
Does the 15 run tomorrow with it being the bank holiday Monday, might have a trip up if it is, cheers!
(30/08/2015 19:20)gka472l Wrote:  Does the 15 run tomorrow with it being the bank holiday Monday, might have a trip up if it is, cheers!
It does indeed.
(30/08/2015 19:28)R557 ABA Wrote:  It does indeed.
Many thanks, shall take a trip up there tomorrow then!
From what I've been told, 14166 needs a new starter motor.
The mess of oil on rear wheels will have been as Scania1996 said,
17502 covering for 14166 on the 15 in New Brighton today https://www.flickr.com/photos/dmc1947/21...ateposted/
It was a good way of advertising the city sightseeing tour of Chester in New Brighton , at least it was better than having a closed top bus doing the service.
(30/08/2015 18:44)Barney Wrote:  That sounds an expensive repair. Could be the end.
Half shafts and front panel removal are common practice for towing a bus, so it doesn't necessarly give us an idea as to what the problem is. As R879 HRF said if it is just the starter motor then it's a simple bolt off, bolt on job
User(s) browsing this thread: 57 Guest(s)
