Current time: 04/11/2026, 04:18 Hello There, Guest! (Login — Register)
A friend has just reported18149 to be on the 471/2.
Can anybody confirm??
(01/09/2015 13:11)R879 HRF Wrote:  A friend has just reported18149 to be on the 471/2.
One of them 04 plates seemed to get on there most days or has this changed
Didn't see that but 18147 is on the 38.
HTH
(01/09/2015 16:01)E208 WBG Wrote:  One of them 04 plates seemed to get on there most days or has this changed
Seen a few on it over the past week or so
There was a Trident with Flip Dot desties in Liverpool today so probably could of been on 471/2
(01/09/2015 08:22)Scania1996 Wrote:  Half shafts and front panel removal are common practice for towing a bus, so it doesn't necessarly give us an idea as to what the problem is. As R879 HRF said if it is just the starter motor then it's a simple bolt off, bolt on job
Unless a rear suspended tow is being undertaken, then removing the half-shafts is essential to avoid winding up the gearbox and causing damage to it and/or the torque converter.
Front panel removal is an obvious one to help access to the undernear/tow points/air connections.
YK53 GXJ (21249) is on the 41\42 today.
18149 was on the 471/2 again yesterday
Enviro400 MMC YY15 HVZ (80027) is on the 41\42 today!
(03/09/2015 07:53)YK53 GXO Wrote:  Enviro400 MMC YY15 HVZ (80027) is on the 41\42 today!
Is this vehicle being cycled through all the routes there is at Rock Ferry , i did think it was only here to be evaluated on the 471/2 after being used out of Gillmoss.
User(s) browsing this thread: 50 Guest(s)
