Current time: 04/11/2026, 09:09 Hello There, Guest! (Login — Register)
New Chester Bus Exchange
RE: New Chester Bus Exchange
Those stands seem so mixed up. Just whatever can work with the timings it looks like. No keeping buses together which go to the same place. Also, as stated earlier, NatEx need 2 stands because of the timings unless they are changing times. Blacons need 2 stands or a layover as they are timed so that 1 bus is in drop off for 3 minutes then drives forward into stand for 5 minutes. Blacons can never keep to time either so normally have 3 in the stand at a time. Will never work.
(16/05/2017 02:53)iMarkeh Wrote:  Those stands seem so mixed up. Just whatever can work with the timings it looks like. No keeping buses together which go to the same place. Also, as stated earlier, NatEx need 2 stands because of the timings unless they are changing times. Blacons need 2 stands or a layover as they are timed so that 1 bus is in drop off for 3 minutes then drives forward into stand for 5 minutes. Blacons can never keep to time either so normally have 3 in the stand at a time. Will never work.
Unless it's changed national express also pics up out side the visitors centre so that probably why it's only got the one stand, I'm sure CWaC and national express liased over the matter but they currently only have the one stand in the current bus station, I one of the stands is for layover of the blacon routes. I do think the planners forgot about layovers when designing this
NatEx only pick up at the bus exchange. No longer at Visitor Centre. NatEx may only have 1 stand but when the 2 buses are in, the Park and Ride goes round into where the 11 used to stop. They normally do that when just 1 natEx is in because they are not brave enough to try and reverse out or do a tight turn. Layovers are not accomedated for whatsoever.
(16/05/2017 11:22)iMarkeh Wrote:  NatEx only pick up at the bus exchange. No longer at Visitor Centre. NatEx may only have 1 stand but when the 2 buses are in, the Park and Ride goes round into where the 11 used to stop. They normally do that when just 1 natEx is in because they are not brave enough to try and reverse out or do a tight turn. Layovers are not accomedated for whatsoever.
Remember that the existing stops on Delamere St will be retained as a layover facilities should they be needed.
Ok, so you are expecting buses to drop off in the bus station to head upto the fountains, turn around then head into Delamere Street. By the time they done all that, it will be time to go back out again. Needs layover much closer. Would make much more sense to have the blacons run the 200 route into Princess Street as everyone wants them to but send them via the new interchange. So run into the new interchange then to princess street before heading out to Blacon again. Saves the 200 being a new bus. Means less layover on Blacons, very regular service to Princess street as everyone wants. Win win if you ask me. Just means the roads have to be big enough for the Pulsar/Eclipse.
Who is operating this new 200 Service anyway?
(22/05/2017 00:39)LJ51 DDA Wrote:  Who is operating this new 200 Service anyway?
Stagecoach, funded by Cheshire West and Chester Council.
(22/05/2017 08:28)YK53 GXO Wrote:  Stagecoach, funded by Cheshire West and Chester Council.
Thank you! Smile
STAND A:
16 Saltney
53 Kingsway
STAND B:
8 Pipars Ash
9 Pipars Ash
21 Frodsham (Sunday)
82 Northwich
84 Crewe
DB1 Mold
DB2 Saltney Ferry
X30 Warrington
100 City Tour (Mon - Sat)
605 Bishops High School
STAND C:
3 Mold
5 Huntington
7 Vicars Cross
9 Mold
26 Guilden Sutton
41/A/B Waverton/Tattenhall/Whitchurch
C56 Wrexham
CRL Rail Stn
X1 Ruthin
STAND D:
Wrexham Road PR
Boughton Heath PR
STAND E:
Zoo PR
Sealand Road PR
STAND F:
10/10A Holywell
1 Liverpool (After 11:30PM)
STAND G:
1, 1A Blacon Circular
STAND H:
15/A Saughall
22 Moreton
DB4 Deeside Indust
100 City tour (Sunday)
200 Princess Street
STAND J:
51 Plas Newton
Drop off 1, 1A, 15, 15A, 22, DB4
STAND K:
1, 2 Birkenhead and Liverpool
STAND L:
X2 Runcorn
X8 Liverpool
26 Ellesmere Port
STAND M:
Drop off for 1, 2, X2, X8
STAND N:
National Express
Clearer image from NWBB: https://www.facebook.com/tnwbb/photos/p....=3&theater
(22/05/2017 16:53)iMarkeh Wrote:  STAND A:
16 Saltney
53 Kingsway
STAND B:
8 Pipars Ash
9 Pipars Ash
82 Northwich
84 Crewe
DB1 Mold
DB2 Saltney Ferry
X30 Warrington
STAND C:
3 Mold
5 Huntington
7 Vicars Cross
9 Mold
26 Guilden Sutton
C56 Wrexham
CRL Rail Stn
X1 Ruthin
STAND D:
Wrexham Road PR
Boughton Heath PR
STAND E:
Zoo PR
Sealand Road PR
STAND F:
10/10A Holywell
STAND G:
STAND H:
15/A Saughall
22 Moreton
DB4 Deeside Indust
200 Princess Street
STAND J:
51 Plas Newton
STAND K:
STAND L:
X2 Runcorn
X8 Liverpool
26 Ellesmere Port
STAND M:
STAND N:
National Express
I can see stand B struggling from time to time. Is there actually anywhere to lay over though?
