Current time: 29/10/2026, 16:12 Hello There, Guest! (Login — Register)
Stagecoach Devon
RE: Stagecoach Devon
(10/07/2015 22:34)gka472l Wrote:  First Plymouth have around 90ish allocated currently.
HTH
That assumes all the existing ex First routes will be registered, It appears that the Torpoint depot is not part of the takeover & rumours are that it will be sold for redevelopment(Housing), so there is a question mark over the Torpoint routes (Go Ahead now compete on these).
It is also likely that existing Stagecoach routes X38 & Gold might have some of their allocation moved to Plymouth.
N.B 93 vehicles last count (probably out of date already) I make it as 32 DDA compliant but I am uncertain about the status of the older ex London Tridents.
Rumour has it (unconfirmed) that the existing First fleet will be hired to Stagecoach short term, with the DDA compliant vehicles returning to First, ASAP.
Stagecoach of course has only @ 5+ months until Dec 31st to replace all the non DDA single deck stock.
(12/07/2015 14:46)Southernsofty Wrote:  That assumes all the existing ex First routes will be registered, It appears that the Torpoint depot is not part of the takeover & rumours are that it will be sold for redevelopment(Housing), so there is a question mark over the Torpoint routes (Go Ahead now compete on these).
Other sources state that the Torpoint services will re-allocate to Plymouth and be Stagecoach run.
HTH
It occurs to me that the CMA may as well approve this deal. If not, it will be like Barnstaple, in that First will dump the network and Stagecoach register a replacement network anyway!
Courtesy of http://www.plymothiantransit.com/ , some registration of the Plymouth services by Stagecoach are now known, of interest if the scenic route 93 between Dartmouth & Kingsbridge (and presumably onto Plymouth but not listed yet) will be numbered 3 under Stagecoach. Copied & pasted below -
PH1020951/235 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
EBSR New Registration Created
Starting Point: Coypool Park & Ride
Finish Point: Plymouth Royal Parade
Via:
Service Number: 200 former PR2
Service Type: Normal Stopping
Effective Date: 07-SEP-2015
Other Details: Mondays to Saturdays except Bank Holidays every 10/12 mins
PH1020951/236 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Starting Point: Royal Parade
Finish Point: Mount Batten
Via:
Service Number: 2 retains same number
Other Details: Daily service upto 20 mins Mon-Sat and hourly on Sundays and Bank Holidays on each service
PH1020951/238 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Starting Point: Kingsbridge
Finish Point: Dartmouth
Via:
Service Number: 3 former 93
Effective Date: 06-SEP-2015
Other Details: Mondays to Saturdays approx hourly, Sundays & Bank Holidays - 4 journeys each way
PH1020951/239 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Via:
Service Number: 3
Other Details: School Terms only from Dartmouth to Kingsbridge
PH1020951/240 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Starting Point: Tavistock Bus Station
Finish Point: Bishopsmead/Courtlands Road
Via:
Service Number: 89
Other Details: Mondays to Saturdays except Bank Holidays approx hourly
PH1020951/248 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Starting Point: Devonport
Finish Point: Coombe Dene School
Via:
Service Number: 806
Other Details: Schooldays, one journey in each direction
PH1020951/249 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Starting Point: Plymouth
Finish Point: Tavistock
Via:
Service Number: 1 former 83 / 86
Other Details: Daily Service.
HTH
More from http://www.plymothiantransit.com/ today (15/7) as most if not all the First cancellations are on there.
PH0004983/32 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Tavistock Bus Station and Plymouth Royal Parade given service number 83/83A/86 effective from 06-Sep-2015.
PH0004983/35 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between TORPOINT FERRY and PLYMOUTH Bus Station given service number 81/81D effective from 06-Sep-2015.
PH0004983/36 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Dartmouth Pontoon and Dartmouth Pontoon given service number 90/90A/90B/90C effective from 06-Sep-2015.
PH0004983/38 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Kingsbridge Quay and Dartmouth Pontoon given service number 93 effective from 06-Sep-2015.
PH0004983/75 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Roborough Bypass and Tor Bridge High given service number 804/805 effective from 06-Sep-2015.
PH0004983/120 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Woolwell and Coombe Dean School given service number 808/807/809 effective from 06-Sep-2015.
PH0004983/144 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between NR MOLTON Bridge and CHIPPENHAMPTON Square given service number 855/856/859 effective from 06-Sep-2015.
PH0004983/145 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between EAST ANSTEY Froude Arms and TAWSTOCK given service number NOT AV. effective from 06-Sep-2015.
PH0004983/186 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between PLYMOUTH Bretonside Bus Station and LAUNCESTON Westgate Street given service number 76 effective from 06-Sep-2015.
PH0004983/278 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between THE GEORGE PARK AND RIDE SITE and PLYMOUTH (Royal Parade) given service number PR1 effective from 06-Sep-2015.
PH0004983/294 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Coypool Park & Ride Site and Royal Parade given service number PR2 effective from 06-Sep-2015.
PH0004983/307 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Tavistock Bus Station and Courtlands given service number 89 effective from 06-Sep-2015.
PH0004983/335 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Plymouth Royal Parade and Saltash given service number 1/1A effective from 06-Sep-2015.
PH0004983/336 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Plymouth Royal Parade and St Budeaux Square given service number 3 effective from 06-Sep-2015.
PH0004983/337 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Plymouth Royal Parade and Mount Batten given service number 2 effective from 06-Sep-2015.
PH0004983/389 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Plymouth, Royal Parade and Kingsbridge Quay given service number 93 effective from 06-Sep-2015.
PH0004983/396 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Plymouth City Centre and Woolwell, School Drive given service number 15/15A effective from 06-Sep-2015.
PH0004983/401 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Harford Bridge and Tavistock given service number 1 effective from 06-Sep-2015.
PH0004983/402 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Lumburn Field and Tavistock given service number 2 effective from 06-Sep-2015.
PH0004983/403 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Yelverton and Tavistock given service number 3 effective from 06-Sep-2015.
PH0004983/429 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Wembury and Burrator given service number 48 effective from 06-Sep-2015.
PH0004983/430 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Barnstaple Bus Station and Croyde Bay, Ruda given service number 8 effective from 06-Sep-2015.
PH0004983/448 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Gunnislake Station and Okehampton Station given service number 187 effective from 06-Sep-2015.
PH0004983/463 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Plymouth, Royal Parade and Laira given service number 6/Purple effective from 06-Sep-2015.
PH0004983/467 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between DEVONPORT and COOMBE DEAN SCHOOL given service number 806 effective from 06-Sep-2015.
PH0004983/471 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Exeter Bus Station and Princetown given service number 48 effective from 06-Sep-2015.
PH0004983/499 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Tavistock Bus Station and Callington, Callington School given service number 79 effective from 06-Sep-2015.
PH0004983/523 - FIRST DEVON & CORNWALL LTD, THE RIDE, CHELSON MEADOW, PLYMOUTH, PL9 7JT
Cancellation Accepted: Operating between Milehouse Park & Ride and Milehouse Park & Ride given service number PR4 effective from 06-Sep-2015.
Of interest are the Saltash & Torpoint routes so presumably Stagecoach will register these themselves.
I shall post info as it becomes known!
HTH
Some Stagecoach registrations now on VOSA -
PH1020951/234 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Registration Accepted
Starting Point: The George Park & Ride
Via:
Service Number: 101
Via:
Service Number: 200
Via:
Service Number: 2
PH1020951/237 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Finish Point: Kingsbridge
Via:
Service Number: 3
Other Details: Monday to Saturday approx hourly, Sundays & Bank holidays - 4 journeys in each direction
Via:
Service Number: 3
Via:
Service Number: 3
Via:
Service Number: 89
PH1020951/241 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Starting Point: Dartmouth
Finish Point: Townstal
Via:
Service Number: 90
Other Details: Daily Service upto every 15 mins Mon - Fri, 30 mins Sat, Sun and Bank Holidays
PH1020951/242 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Starting Point: Princetown/Burrator/Plymouth
Finish Point: Wembury
Via:
Service Number: 48
PH1020951/243 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Starting Point: Exeter
Finish Point: Princetown
Via:
Service Number: 48
Other Details: Sundays & Bank Holidays until 13 September 2015, then from 29 May until mid September 2016 and at similar periods each year.
PH1020951/244 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Starting Point: Dartmouth Park & Ride
Finish Point: Dartmouth Pontoon
Via:
Service Number: 91
Other Details: Daily Service every 20 mins
PH1020951/245 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Starting Point: Woolwell
Via:
Service Number: 807
Other Details: Schooldays only, One journey in each direction
PH1020951/246 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Starting Point: Milehouse
Via:
Service Number: 808
PH1020951/247 - STAGECOACH DEVON LTD T/A Stagecoach South West, BELGRAVE ROAD, EXETER, EX1 2LB
Starting Point: Widewell/Robouough
Finish Point: Tor Bridge High School
Via:
Service Number: 805
Other Details: Schooldays only, one journey in each direction on each sservice
Via:
Service Number: 806
Via:
Service Number: 1
HTH
Expected at Stagecoach Devon are former Carlisle '14' plate Enviro200's - 37113-37121, very possibly for use in Plymouth. credit - Stagecoach Enthusiasts facebook group
HTH
(19/07/2015 19:56)Dentonian Wrote:  Is there any news on other transfers? I ask as the redundant stock at Wigan has depleted somewhat since this takeover was announced.
Several Tridents (10) from the Stagecoach West fleet due to transfer to South West, likely Plymouth, that's all I've heard mentioned in the last day or so.......
Solo's 47081-3 to move to Stagecoach Merseyside & South Lancashire later this week, 47084-47090 for use in Plymouth.
HTH
37113-37116 now in Devon, also a slight change to the planned Solo's for Plymouth, 47084/6-91 are the ones planned to go to Plymouth (no idea why 47085 isn't....), also the CMA is to investigate the sale http://www.plymothiantransit.com/2015/08...igate.html
HTH
