Current time: 02/11/2026, 19:42 Hello There, Guest! (Login — Register)
Roger Farnworth Railways
Re: Les Trains du Col de Tende - Part 2
In the first article about the line from Cuneo to the sea we covered the length from Cuneo to Vernante. This article covers the next length of the line from Vernante to Limone.
The Line South from Vernante to Limone
A schematic drawing showing the main locations on the line from Vernante to Limone.
Quote:Banaudo et al write that “It was only in 1886, after the creation of the Rete Mediterranea, that the work on the fourth tranche from Vernante to Limone was awarded. It was 8,831 m long and had a gradient of 203 m, which was to be compensated for by a continuous ramp of up to 26 mm/m. This value would not be exceeded at any other point on the line. On this section, the rail remained constantly on a ledge on the steep slope on the right bank of the Vermenagna, where it was anchored by eleven bridges and viaducts totaling sixty-three masonry arches, as well as nine tunnels with a combined length of 4,416 m, or just over half the route:”
We start this next length of the journey at Vernante Railway Station and head Southeast.
http://rogerfarnworth.com/2025/07/26/the...eo-part-2/
RE: The Railway between Nice, Tende & Cuneo - Part 3
Vievola to St. Dalmas de Tende
http://rogerfarnworth.com/2025/08/06/the...-de-tende/
Our journey South down the line continues from Vievola. …
RE: Roger Farnworth Railways
A Turn of the 20th Century Proposed Tramway in the Valley of La Roya
While finding out about the line between Cuneo and the Mediterranean coast, I found a few paragraphs in the French language book about the railway which crossed the Col de Tende by Jose Banaudo et al. Those paragraphs were about a proposed tramway that in the end did not get built. … The featured image in the linked article is a map showing the full length of the proposed line.
Late in the 19th century before a rail link from Vievola to the Mediterranean was really on the agenda. Alongside the experimental ‘Train Scotte’, (see https://rogerfarnworth.com/2025/07/26/mi...-vehicles) a “local engineer, M. Chatelanat, proposed building a tramway line between Vievola station … and Ventimiglia. He knew the region well, having just overseen the construction of the rack railway from Monte Carlo to La Turbie. (see https://rogerfarnworth.com/2017/11/23/mo...ovence-15)
He presented an application filed on 7th February 1899.” …....
The submission made by M. Chatelanat began, “The electric tramway for which we are requesting a concession is intended to facilitate the movement of passengers and goods in the Roya Valley through a rapid, convenient, and economical means of communication. Currently, to reach Nice and the other communes of the department, the population of the French part of this valley must either travel more than 60 kilometres along the old Nice-Cuneo road, crossing the foothills of Brouis and Braus, in unsafe conditions due to the steep slopes, the height of the passes, and, in winter, the seasonal inclement weather. Or, since the opening of the national road from Breil to Ventimiglia, travel approximately 30 kilometres and cross two customs lines to join the coastal railway line in Ventimiglia. … Between the coast and Upper Piedmont, especially the province of Cuneo, there is a very intense movement of population every year, but if you want to go by train, you have to make a long detour via Savona, which is long and expensive. The province of Cuneo sends to Nice and the coast some of its products that our region cannot obtain elsewhere. On the other hand, our particular products from the South are in demand and consumed in the upper Po Valley. Facilitating the movement of travelers and this exchange of products between Piedmont and the coast will at the same time allow the French populations of the Roya Valley to come easily and quickly to Nice to stock up and connect with the entire French coast without having to cross the Braus and Brouis passes, such is the goal we are pursuing.”
There were a number of projects of this nature being explored at the time. The tramway between Menton and Sospel is an excellent example (see http://rogerfarnworth.com/2018/02/23/the...rovence-51 and http://rogerfarnworth.com/2018/06/08/the...vence-61). Others in the valley of the River Var and in the valley of the River Paillon were also built.
This is what we know about the proposed tramway: ...
http://rogerfarnworth.com/2025/07/27/a-t...th-century
Part 4 - South from St. Dalmas de Tende
The featured image in the linked article is a poster for the Nice-Cuneo line. It shows Scarassoui Viaduct with a Northbound steam service between the wars, designed by Adolphe Crossard. … Public Domain.
In the first three articles about the line from Cuneo to the sea we covered the length of the line from Cuneo to St. Dalmas de Tende. In the linked article we head South from St. Dalmas de Tende.
http://rogerfarnworth.com/2025/08/16/the...-sur-roya/
Part 5 - Breil-sur-Roya to Airole and Ventimiglia
This article follows the line South from Breil-sur-Roya to Ventimiglia in two parts: the first as far as Airole and the second from Airole to Ventimiglia. ….
http://rogerfarnworth.com/2025/08/25/the...ntimiglia/
Re: The Importance of the Stockton and Darlington Railway
The Stockton and Darlington Railway
On 27th September 2025 we marked the bicentenary of the Stockton & Darlington Railway which is accepted the world over as one of the most significant developments in the history of railways, the precursor of all that was to follow in the development of railway networks throughout the world. That day, Locomotion No. 1 pulled a long train along the Stockton and Darlington Railway. …………
I was asked to give a talk by the Friends of Ironbridge Gorge Museums Trust entitled, 'What was so special about the Stockton & Darlington Railway?' The link below is to my notes for the talk. ....
http://rogerfarnworth.com/2025/09/29/the...n-railway/
These were condensed somewhat to suit the time available. ...
The Khushalgarh-Kohat-Thal Railway in Pakistan
The featured image at the head of the linked article is an early view of Thal Railway Station, possibly as early as 1903.
By 1881, Khushalgarh had been connected by a short 7 mile (11 kilometre) broad gauge spur to Jand the North Western Railway main line.
The length from Khushalgarh to Kohat was initially built to the 2ft 6in narrow gauge in 1902 but converted to broad gauge (5ft 6in) at the same time as the River Indus was bridged, reopening in 1908. The line from Kohat to Thal was built to the narrow gauge (2ft 6in) and opened in stages from 1901 to 1903.
Khushalgarh-Kohat-Thal Railway was worked by the North Western Railway. It was a military railway which ran close to the border with Afghanistan, linking the border town of Thal with the wider network at Khushalgarh.
http://rogerfarnworth.com/2025/09/25/the...-pakistan/
Part 6 – Breil-sur-Roya to L’Escarene.
The featured image in the linked article shows an unidentified steam locomotive crossing the highly unusual Viaduc de Bevera. The train is heading toward Sospel.
The article begins the journey from Breil-sur-Roya to Nice. ... South of Breil-sur-Roya a junction allows direct access to Ventimiglia and to Nice.
http://rogerfarnworth.com/2025/08/29/the...lescarene/
Re: David Gwyn; The Coming of the Railway: A New Global History,
A review of what Yale University Press calls, 'The first global history of the epic early days of the iron railway.'
http://rogerfarnworth.com/2025/10/04/dav...haven-2023
I found this book to be easy to read and yet deeply scholarly. A superb, informative and enjoyable read! It is not too often that you find a railway history book as readable as a novel.
It seems to me that it is possible that the individual chapters are developed from the text of a series of lectures on early railway history. The readable text is backed up by very comprehensive notes and references. There is also a wide-ranging bibliography.
Part 7 – L’Escarene to Drap-Cantaron Railway Station[/b]
This article begins the journey from L’Escarene.
Initially, the line heads Southeast but then gradually turns to the the Southwest through Peille, Peillon and Drap before running into Nice.
http://rogerfarnworth.com/2025/09/26/the...ay-station
