Current time: 04/11/2026, 15:49 Hello There, Guest! (Login — Register)
(03/02/2015 15:43)Barney Wrote:  4618 on the 89?
4618 was indeed on the 89 today as per mms post above.
Thanks!
updated 21/08/17
Allocating the spare Enviro400s to busy 89 workings is a good idea. 4618 was certainly carrying a healthy load on its way out of St Helens.
2986 sounds very poorly now, it jumped out of gear whilst on the 352 before finding its gears again - however, after this there was an awful jolt and 'dull' noise upon deceleration - with almost every gearchange down through the gearbox. This happened whilst changing up a few times too. Didn't sound very good at all and you could even hear it outside the bus too, the banging noise.
_______________
Formerly MX59 JZJ
The 2150 89 from St Helens has been swapped for 2976. The practice of swapping this journey over to Pulsars happened regularly when mostly Volvos ran the service.
Well they have put a decker out on the 352/395 today.
MM, Do you know which board the decker is allocated to?
_______________
Formerly MX59 JZJ
The decker on the 352 is 4606.
Thanks!
updated 21/08/17
4596 on 89 but not on the boards said before, it was on the 11.50am from St Helens to the Airport
(04/02/2015 10:29)MX59 JZJ Wrote:  MM, Do you know which board the decker is allocated to?
It was 105 board
May of been previously mentioned but has 2214 been withdrawn. Not seen it for a while.
As I understand it the 25 deckers into St Helens should have replaced the following:
2701-2710 to Green Lane to displace 3062-3068, 3154 (Midlands) & 3069/70 (Shires)
3023-26 & 3047/8 to Green Lane to displace 3071-3076 (Shires)
2988-90 to Birkenhead to displace 3123-25 (Shires)
2991-93 to Southport to displace 3079-81 (Shires)
2676 to Wythenshawe
plus 3 other single decks to be disposed of?
User(s) browsing this thread: 78 Guest(s)
