Current time: 05/11/2026, 12:28 Hello There, Guest! (Login — Register)
first run pulsar
2nd run anything free in depot
3rd run pulsar
The early morning tends to be pulsar operated due to it goi.g onto a 10/10A after it,the afternoon one can be anything thats in the depot due to the driver taking the bus from depot and evening it tends to be pulsar again.
Iv had 2696 on the 10 to night from old swan to St.Helens and the driver was nailing it not a bad pulsar to end the day!
Here is my Flickr photo stream why dont you take a look! It was last updated: 15/05/13
2702 on the 10A, think this started the day on the 89.
2492 on 33 again!
Solo 677 is on the 32A today.
Thanks!
updated 21/08/17
2298 is on the 35! this bus spends most its time on the 37/38
not one but 2 cadets on the 33 one is 2492, cadets are to small for the route
2298 does not spend most of its time on the 37/38, it's allocated as normal as per any Dart. Cadets also aren't unusual on any of St Helens' local routes with, perhaps, the exception of the 35/A and 36/A. With regards to them being too small, they're the same size as most Darts and bigger than the Solos coming to operate the local routes. A B39F vehicle is perfectly suited to the 33/A - it doesn't regularly need anything bigger.
i had the cadet before standing load and that could be true about 2298 its just i seen it 3 times recently all the time on the 37/38 while the other 2 pointer 21's seem be on 20 most the time for some odd reason
Like I say, Cadets are the same size as allocated Darts. Also bear in mind that a standing load does not necessarily indicate a need for larger buses and one journey is likely not to be reflective of the whole service.
User(s) browsing this thread: 110 Guest(s)
