Current time: 03/11/2026, 15:56 Hello There, Guest! (Login — Register)
507003 worked on the Chester line yesterday and I believe 018 and 029 were out as well
(08/11/2024 11:50)507022 Wrote:  507003 worked on the Chester line yesterday and I believe 018 and 029 were out as well
All three out again today as well, with 507003 working on the New Brighton line and 018 and 029 on the Southport peak workings.
Is there any way of knowing what lines the 507's are on today as want to try get one last ride on them?
They’ve been stabled at New Brighton and Southport lately and will take over if a 777 fails, dependant on crew knowledge, but it could happen on any line at any time, so I don’t think there is any way you can find out other than going to Southport or Hamilton Square and see if any show up!!!
Just one out today: 507003 is on the New Brighton line, working the .53 past the hour circuits from NB potentially until 18.53. However, with the 507s very much in 'Fergie time' it could be substituted at any time.
Reduced timetable in operation tomorrow, Tuesday 12th Nov. on the Headbolt Lane and New Brighton lines due to Class 777 availability issues.
Reports the Class 777 fleet require an inspection due to a problem that has been found with the motors.
https://www.merseyrail.org/journey-plann...-november/
507018/029 were booked to operate from Southport this morning, but can’t confirm at the moment whether they actually did run.
(11/11/2024 23:08)508134 Wrote:  Reduced timetable in operation tomorrow, Tuesday 12th Nov. on the Headbolt Lane and New Brighton lines due to Class 777 availability issues.
You’re correct - each unit needs to be checked
With the 777 checks, 507003 has been working on the Wirral and 507018/029 on the Southport line for the third consecutive day
(09/11/2024 07:15)KX03 KYY Wrote:  Is there any way of knowing what lines the 507's are on today as want to try get one last ride on them?
I would assume you may have a fair chance of getting them on the Southport line tomorrow if the last few days are anything to go by.
