Current time: 04/11/2026, 19:16 Hello There, Guest! (Login — Register)
I believe 151 was written off in an accident some time ago There are usually 4 of them at Wincham
(21/12/2018 01:46)ant17612 Wrote:  Can anyone advise what happened to Streetlite 151 MX60 GWO. Doesn't appear on the D&G fleetlist on their site and also no results on Flickr for well over 3 years now...
Works for me
D&G had the same number of Streetlites and 13 reg Solo SRs when they originally did the allocation change for the Streetlites to take the place of the SRs at Wincham.
Only one Enviro on the 82 today. A Streetlite and a Solo SR are the other vehicles being used.
Additions to fleetlist - new 2008 despite registrations.
26 T26 TYB Optare Versa V1110 Red Adderley Green
27 T27 TYB Optare Versa V1110 D&G Yellow 9 Adderley Green
28 T28 TYB Optare Versa V1110 Red Adderley Green
Only withdrawal I can spot is Pn Centro 149
(02/01/2019 19:21)mikestone Wrote:  Additions to fleetlist - new 2008 despite registrations.
All three are ex Yellow Buses Bournemouth
Doesn't look like any noticeable changes between the Crewe and Adderley Green allocations, which is perhaps surprising considering since they took on the 82 there's been fewer larger buses available for other Cheshire routes.
Incidentally, saw a 82 passing through Hartford at lunchtime today which had no passengers on board. Perhaps that's the issue Arriva had with the 82 - loads of passengers on some services and fresh air on others, which makes it difficult to use suitable size vehicles.
(02/01/2019 20:26)knutstransport Wrote:  Incidentally, saw a 82 passing through Hartford at lunchtime today which had no passengers on board. Perhaps that's the issue Arriva had with the 82 - loads of passengers on some services and fresh air on others, which makes it difficult to use suitable size vehicles.
That is definitely true. You can probably run the 82 with streetlites during school holidays and Saturdays. The issue is that on school days, due to how the routes work, all 3 buses serve the college and that is the reason as to why bigger buses are needed. If they got the decker for these school trips, a streetlites would do perfectly fine covering all other trips I think. With the exception of the schools, very few trips are busy.
102 running Macclesfield-Altrincham services today. First time in months I've seen a Solo SR on the 88.
There were 2 SRs on there yesterday, 102 and 104 Solos 45 and 49 are unwell and have gone to Crewe for repairs. Unbranded Enviro200 33 has been on 82s this week.
(05/01/2019 11:40)knutstransport Wrote:  102 running Macclesfield-Altrincham services today. First time in months I've seen a Solo SR on the 88.
Works for me
Are there any plans for Adderley Green and Crewe Depot's to go over to Ticketer operation? Just seems odd that while Winchem are on Ticketers other D&G depots are still on the old Wayfarers which the scanners for the free passes don't work on them now for some reason.
