Current time: 03/11/2026, 12:32 Hello There, Guest! (Login — Register)
DB Cargo
RE: DB Schenker
(22/03/2014 22:22)R311 WVR Wrote:  Is 950001 DB operated?! I knew the 97's were operated by them, but didn't know about the 950!
I think so, the driver had a DB vest on
RE: DB Schenker
(23/03/2014 08:18)Daniel Anderton Wrote:  I think so, the driver had a DB vest on
He may be a DBS driver but the unit is owned by Network Rail.
RE: DB Schenker
(23/03/2014 18:17)childwallblues Wrote:  He may be a DBS driver but the unit is owned by Network Rail.
Indeed it is
RE: DB Schenker
Have noticed that some Sheds have obtained Sheep logos applied at Margam
Cheers
Rob Day
Formerly
51537
RE: DB Schenker
60087 is to be repaired and overhauled at Toton for use by Colas Rail.
RE: DB Schenker
Long stored 90037 is to be overhauled and returned to service as the second of the class for hire to DRS.
RE: DB Schenker
(29/03/2014 07:01)childwallblues Wrote:  60087 is to be repaired and overhauled at Toton for use by Colas Rail.
Up to ten Class 60 are to go on hire to Colas Rail.
RE: DB Schenker
If the DRS 68's are going to take over the Chiltern work in the near future , DBS are going to have some Class 67's available for new work , but is there any more work available at the moment for them ?
RE: DB Schenker
(12/05/2014 21:21)wirralbus Wrote:  If the DRS 68's are going to take over the Chiltern work in the near future , DBS are going to have some Class 67's available for new work , but is there any more work available at the moment for them ?
Gives Scotrail (Sleepers and Fife workings) and Arriva Trains Wales a bit of flexibility in case of a loco failure. East Coast also use them for the static "Thunderbird" duties on the ECML.
The problem has never really about having enough locomotives, it's always a lack of suitable carriages for them to haul!
RE: DB Schenker
60024 has received the Clitheroe Castle nameplates previously on 60029.
