Current time: 20/11/2026, 01:38 Hello There, Guest! (Login — Register)
Northern (Arriva Rail North)
A 319 is covering the dmu timed diagram on the Alderley Edge route which includes the 08.04 and 20.04 to Crewe.
Here's the new timetable from May 2018 for Northern.
http://www.realtimetrains.co.uk/search/a...wtt&toc=NT
(12/02/2018 13:55)boby32 Wrote:  Here's the new timetable from May 2018 for Northern.
Like it was said a few pages back that's a provisional timetable, services may yet be added, removed or re-timed.
150101 was noted on the 14:27 Liverpool - Manchester Oxford Road
319384 was I understand on the Alderley Edge diagram today.
Interesting! Not sure if I'm reading/searching this wrong, but it looks like they have come up with a novel solution to reduce overcrowding on the 1649 & 1705 Hope Valley trains from Picc - simply withdraw the 1705 (and retime the 1717 by two minutes!). I question my ability to search as its not a format I've seen before as a layman, so can't be sure that there isn't still a train at roughly 1705 - but it's just reduced stops.
150101 went to Allerton as part of the 2333 departure from Lime St so could be on anything today if it comes back off the depot today
(12/02/2018 21:33)Brickmill Wrote:  Interesting! Not sure if I'm reading/searching this wrong, but it looks like they have come up with a novel solution to reduce overcrowding on the 1649 & 1705 Hope Valley trains from Picc - simply withdraw the 1705 (and retime the 1717 by two minutes!). I question my ability to search as its not a format I've seen before as a layman, so can't be sure that there isn't still a train at roughly 1705 - but it's just reduced stops.
There's loads of services missing at the moment, only those with approved paths appear and even then they are subject to change. If you believe what it says currently stations between Greenbank and Chester will have no off-peak services!
Just found out that the final Northern timetables for the May 2018 timetable change have been delayed until 8th March, usually they would be available 12 weeks in advance of the change.
(13/02/2018 10:49)knutstransport Wrote:  Just found out that the final Northern timetables for the May 2018 timetable change have been delayed until 8th March, usually they would be available 12 weeks in advance of the change.
Please ignore the new timetable on RTT for the moment.
