Current time: 06/11/2026, 05:32 Hello There, Guest! (Login — Register)
The Wrightbus EVs will enter service on Tuesday, they will only be used on services 10A/82/86/86C for the time being.
10837 also now in Metro livery
Thanks!
updated 21/08/17
82401 MF26EFT
82402 MF26EFU
82403 MM26UMJ
82404 MM26UMK
82405 MM26UML
82407 MM26UMO
82409 MW26XYS
82410 MW26XYT
82411 MW26XYU
82413 MW26XYX
82416 MW26XZA
82420 MW26XZE
82425 MW26XZK
82437 MF26DZK
82439 MF26DZL
These are all in Gillmoss tonight, many of which are likely to be in service tomorrow!
(09/06/2026 00:46)buses7675 Wrote:  82401 MF26EFT
82402 MF26EFU
82403 MM26UMJ
82404 MM26UMK
82405 MM26UML
82407 MM26UMO
82409 MW26XYS
82410 MW26XYT
82411 MW26XYU
82413 MW26XYX
82416 MW26XZA
82420 MW26XZE
82425 MW26XZK
82437 MF26DZK
82439 MF26DZL
82408 went past me not in service, plate is MW26XYR
So far I’ve noticed 10835 & 10841 are actually two new buses on the bus map is there any other new buses tracking as older vehicles??
Some E400MMCs released by these Metro spec Electroliners could be held back for St Helens services in case any StreetDecks are late.
I wonder whether the plan is to run Electroliners on the partnership with Arriva routes and Enviro 400EVs on the Stagecoach local routes?
(13/06/2026 06:18)Metroline1511 Wrote:  Some E400MMCs released by these Metro spec Electroliners could be held back for St Helens services in case any StreetDecks are late.
Believe St Helens is getting 16 Enviro400 MMC from stagecoach be put into st helens. 10830-43 and 3 others. Worth noting that these are being painted into metro livery but keeing stagecoach interior
(13/06/2026 07:12)chris-s Wrote:  Believe St Helens is getting 16 Enviro400 MMC from stagecoach be put into st helens. 10830-43 and 3 others. Worth noting that these are being painted into metro livery but keeing stagecoach interior
The other 3 must be 10565/7/818 which are in METRO livery??
Isn't it the case that St Helens is not getting electrified yet, so won't be able to run Electroliners, only diesel buses?
Also, on commencement of Franchising at St Helens, won't Arriva lose their share of the 10/10A services and they will be 100% Stagecoach from St Helens depot?
(13/06/2026 11:33)Olympian2100 Wrote:  Isn't it the case that St Helens is not getting electrified yet, so won't be able to run Electroliners, only diesel buses?
St helens will be a all diesel fleet
10 and 10a will remain in St Helens as the franchise was won on the routes currently in each depot. The stagecoach 10a operation will move to St Helens in September
