Current time: 20/11/2026, 01:18 Hello There, Guest! (Login — Register)
Northern (Arriva Rail North)
(17/02/2018 20:37)boby32 Wrote:  Here's a video of 150123 and 150110 doing a service between Liverpool Lime Street and Manchester Victoria. Normally, this is booked as 319.
https://www.youtube.com/watch?v=aZl9Pii1_nQ
In a four car non through gang-wayed set like the 150/1 does the Guard have to be in the rear set to ensure a presence , its not a problem on there sister sets the 150/2 .
As Northern will soon have 50 of these sets the problem will increase.
(18/02/2018 08:50)wirralbus Wrote:  In a four car non through gang-wayed set like the 150/1 does the Guard have to be in the rear set to ensure a presence , its not a problem on there sister sets the 150/2 .
It should be noted it's Northern policy that the guard must be on the rear unit in such circumstances and must close the doors from the rear set even if it's 2 x 150/2s. GWR allow the guard to move between sets when it's 2 x 150/1s.
Does that apply to 319s?
(18/02/2018 10:46)childwallblues Wrote:  Does that apply to 319s?
I don't think the 319s ever operate in multiple while in passenger service but if they did then yes.
319s operate as 8 car for Northern but the rear set is always locked out of use as the platforms are too short.
(18/02/2018 09:57)knutstransport Wrote:  It should be noted it's Northern policy that the guard must be on the rear unit in such circumstances and must close the doors from the rear set even if it's 2 x 150/2s. GWR allow the guard to move between sets when it's 2 x 150/1s.
Not correct. If the sets have a through gangway the Guard can release the doors from anywhere, but can't close them from the leading end of the front set. Any other position is OK.
SD.
Not correct,it is booked for 2 x DMU
(20/02/2018 02:05)Gordon V Wrote:  Not correct,it is booked for 2 x DMU
Why is it booked as 2 x DMU?
(20/02/2018 07:13)boby32 Wrote:  Why is it booked as 2 x DMU?
Because the previous working comes in via Warrington Central which isn't electrified
