Current time: 05/11/2026, 05:27 Hello There, Guest! (Login — Register)
(02/12/2012 19:29)wirralbus Wrote:  507014 is indeed a no split 6 at this prsent time , the unit it is paired with is the good unit .
Its paired with 507012 they ran the first train to ormskirk this morning i rode 012 for the first time since it re-entered service superb unit!
(03/12/2012 16:36)First Class Wrote:
(03/12/2012 08:04)jtd508110 Wrote:  The West Kirby am 6 car is short formed this morning with 508112 taking the brunt. Yesterday it was on the West Kirby line with 508104. I wonder if it is due to 104 failing or something else? 508139 is out on the West Kirby line again today, must be 4 or 5 days on the run that it has ran West Kirby's, although it is on the diagram which will see it replaced at West Kirby and (hopefully) replaced by a 6 car at around 4:30pm. Then it will support the Ellesmere Port line service.
Still waiting for Merseyrail to specify reason for cancellation in TRUST.
2W03 0706 West Kirby: This train has been cancelled due to an unknown reason (TZ)
2W04 0721 West Kirby: This train started from Birkenhead North due to an unknown reason (TZ)
The unit for the 0706 (which should of earlier formed the 0551) didn't make it off Birkenhead North depot until around 0800!
The unit for the 0721 was actually pinched to form the 0621 as the origional unit was also stuck on the depot.
Noticed this morning a further unit that has had the cab air con equipment fitted is the fleet pioneer 507001 it was working the first train to ormskirk this morning with 507017.
will the old hall road depot siding ever see use by emu's again
(05/12/2012 20:59)507 mad Wrote:  will the old hall road depot siding ever see use by emu's again
you come out with some random questions!
It sees semi-regular use already, usually during engineering work or unexpected disruption.
Questions and answers are what the forum is about First Class. There was an issue with the west kirby 6 car pm peak today. I think 507014 and 508115 developed a fault on the depot, so 507004 had to run 3 car, not sure if the fault was rectified by time 004 reached birkenhead north as it may have done a set swap on platform 3.
A network rail test train ran to rock ferry today formed of 31285, some mk2's and either 9701 or 9702, correct me if i have got it wrong. got some excellent shots as well of the beast.
would like to see how that can happen as the is no longer any track where the depot used to be and has been like that for a long time
(07/12/2012 14:30)dave4jackie Wrote:  would like to see how that can happen as the is no longer any track where the depot used to be and has been like that for a long time
Unfortunately you are mistaken.
One siding, capable of holding a 9-car EMU consist was retained. It is known as the Wallside Siding. ML87 (Hall Road, Dn Southport platform) has a subsididary signal which can be cleared to proceed into the siding.
Before Hall Road TMD was axed, any trains entering the depot from the mainline would have to reverse in the siding.
ML1060 is a shunt signal which controls access from the siding towards Hall Road.
[Image: 2994480_e81f7790.jpg]
i knew about that oneBlush i was talking about the depot
User(s) browsing this thread: 27 Guest(s)
