Current time: 19/10/2026, 14:07 Hello There, Guest! (Login — Register)
2023 Cascade
RE: 2023 Cascade
15 Pulsars will be moving out of St Helens in the next few weeks as they reach the 15 year age limit.
They will be replaced with 15 newer examples from Wakefield (10) and Castleford (5)
3 Enviros from Bootle 4411/4419/4420 will be swapped with 3x 64 plates from Leicester Thurmaston. 3 Pulsars will also be swapped with Pulsars from Derby.
1 Pulsar from Birkenhead swapped to Dewsbury
Further buses will be swapped once replacements are sourced
In addition, when Bolton closes 23/9 buses will be transferred to Wythenshawe and Runcorn once run in begins.
RE: 2023 Cascade
I believe 2920-3 are leaving Green Lane soon as well.
RE: 2023 Cascade
When Bolton closes does anybody know which depot/s will be getting the 362/575 Sapphire branded Pulsars?
Will they be repainted before they enter service or will they just enter service in their branded Sapphire livery?
RE: 2023 Cascade
(14/09/2023 05:22)M60lad Wrote:  When Bolton closes does anybody know which depot/s will be getting the 362/575 Sapphire branded Pulsars?
The CX58 ones will go to Runcorn 2995-2999 will go to Wythenshawe and they probably won’t be repainted due to age
RE: 2023 Cascade
They're replacing Sapphire Enviro300s on the 263 aren't they so remove the 362/575 branding and run in plain Sapphire livery would work.
Was jcksmnr
RE: 2023 Cascade
The following are leaving the fleet.
2670 CX58EUM, Midlands.
2689 CX58EWB, Yorkshire.
2691 CX58EWD, Yorkshire.
2692 CX58EWE, Yorkshire.
2693 CX58EWF, Yorkshire.
2694 CX58EWG, Yorkshire.
2695 CX58EWH, Yorkshire.
2696 CX58EWJ, Yorkshire.
2697 CX58EWK, Yorkshire.
2900 CX58EWO, Yorkshire.
2901 CX58EWP, Yorkshire.
2902 CX58EWR, Yorkshire.
2903 CX58EWS, Yorkshire.
2904 CX58EWT, Yorkshire.
2917 CX58EXJ, Midlands.
2918 CX58EXK, Midlands.
2919 CX58EXL, Yorkshire.
As already mentioned, 4411, 4419, 4420 are going to Midlands.
RE: 2023 Cascade
Bootles 3 enviros are being swapped for the following 3 from
4416 YX64 VOP
4417 YX64 VOT
4418 YX64 VOU
RE: 2023 Cascade
Full list of the current batch of buses moving and what is replacing them
ST HELENS 2689 CX58 EWB swapped with WAKEFIELD 1456 YJ62 JHU
ST HELENS 2691 CX58 EWD swapped with WAKEFIELD 1457 YJ62 JJO
ST HELENS 2693 CX58 EWF swapped with WAKEFIELD 1458 YJ62 JNU
ST HELENS 2694 CX58 EWG swapped with WAKEFIELD 1459 YJ62 JPX
ST HELENS 2695 CX58 EWH swapped with WAKEFIELD 1460 YJ62 JPY
ST HELENS 2697 CX58 EWK swapped with WAKEFIELD 1461 YJ62 JRV
ST HELENS 2692 CX58 EWE swapped with WAKEFIELD 1462 YJ62 JTO
ST HELENS 2696 CX58 EWJ swapped with WAKEFIELD 1463 YJ62 JUA
ST HELENS 2900 CX58 EWO swapped with WAKEFIELD 1464 YJ62 JVE
ST HELENS 2901 CX58 EWP swapped with WAKEFIELD 1465 YJ62 JVG
ST HELENS 2902 CX58 EWR swapped with CASTLEFORD 1466 YJ62 JYH
ST HELENS 2903 CX58 EWS swapped with CASTLEFORD 1478 YJ62 JSY
ST HELENS 2904 CX58 EWT swapped with CASTLEFORD 1479 YJ62 JUC
BOOTLE 4411 CX58 FZZ swapped with THURMASTON 4416 YX64 VOP
BOOTLE 4419 CX58 GBV swapped with THURMASTON 4417 YX64 VOT
BOOTLE 4420 CX58 BBY swapped with THURMASTON 4418 YX64 VOU
BOOTLE 2917 CX58 EXJ swapped with DERBY 3767 FJ13 FYM
BIRKENHEAD 2919 CX58 EXL swapped with DEWSBURY 1495 YJ62 JMX
BOOTLE 2937 MX09 EKT swapped with DERBY 3768 FJ13 FYW
BOOTLE* 2926 CX58 FZH swapped with DERBY 3769 FJ13 FYX
ST HELENS 2939 MX09 EKW swapped with CASTLEFORD 1880 YJ62 JUF
ST HELENS 2940 MX09 EKY swapped with CASTLEFORD 1481 YJ62 JVH
*2926 currently at Southport
RE: 2023 Cascade
Lots of movement there.
RE: 2023 Cascade
(22/09/2023 10:29)Route102 Wrote:  Full list of the current batch of buses moving and what is replacing them
2918 is on the first list but 2937 shows on the second....presumably 2918 isn't leaving just yet then?
