Current time: 04/11/2026, 21:38 Hello There, Guest! (Login — Register)
(25/08/2017 16:43)sth77 Wrote:  There are 5 to be done including 4438. They are 4437/39/41/42.
Maybe someone can confirm but I think 4437 is the next one to be done.
Will they use the Enviro400s or any single decker such as the Pulsars then when any of them are being done or do they have enough not to need any more buses to replace them temporary
(26/08/2017 10:56)darylyates17 Wrote:  Will they use the Enviro400s or any single decker such as the Pulsars then when any of them are being done or do they have enough not to need any more buses to replace them temporary
Enviro 400s and pulsars are used on the 89 daily along with the Gemini 2s.
Thanks!
updated 21/08/17
(26/08/2017 11:16)sth77 Wrote:  Enviro 400s and pulsars are used on the 89 daily along with the Gemini 2s.
I knew that id seen Enviro400s and Pulsars on the 89 recently and sometimes the Geminis are used on the 10/10A. Are the Pulsars staying on the 89 or will they go eventually
(26/08/2017 12:28)darylyates17 Wrote:  I knew that id seen Enviro400s and Pulsars on the 89 recently and sometimes the Geminis are used on the 10/10A. Are the Pulsars staying on the 89 or will they go eventually
The Geminis should be on the 89 releasing the Pulsars of to other routes, but I will expect to see the Pulsars popping up on the 89 along with Enviro 400s.
Thanks!
updated 21/08/17
You will see a mixture. Geminis, Enviro400s. At the end of the day, a decker is a decker, thats how its seen. Thats why you see Geminis on the 10s and Enviro400s on the 89s on a daily basis.
(26/08/2017 15:34)sth77 Wrote:  The Geminis should be on the 89 releasing the Pulsars of to other routes, but I will expect to see the Pulsars popping up on the 89 along with Enviro 400s.
Are Sunday turns on the 89 booked for Pulsars still or is it now booked for deckers also??
(27/08/2017 18:11)LJ51DCX Wrote:  Are Sunday turns on the 89 booked for Pulsars still or is it now booked for deckers also??
Depends whos allocating them in the morning.
2720 has been on the 37 today and I saw a Pulsar on the 89 before (not sure which one though)
(29/08/2017 16:20)darylyates17 Wrote:  2720 has been on the 37 today and I saw a Pulsar on the 89 before (not sure which one though)
Pulsars are common on the 89, mix of decker and pulsars
Same with 10/10A it's a mixture
Does anybody know the route for tomorrow's RivFest festival in Warrington? For more info follow the link click here and see posts 236 & 237.
Presumably it will be St Helens Pulsar 2's branded with Viola Beach's band members on shuttle dutys.
User(s) browsing this thread: 72 Guest(s)
