Current time: 29/11/2026, 23:10 Hello There, Guest! (Login — Register)
RE: Stagecoach Manchester
19054 out in place of the Magic Bus vehicles on the 142 this afternoon.
I don't think that happens often, I've never personally seen an Enviro400 on Magicbus duties! Smile
Thanks,
Liam Moskwin.
[Image: 10p9e80.gif]
Happens occasionally - ended up doing that myself a few times.Of course, you've never been around on New Years Eve... All 142/3s are run by Enviros that night.
(24/09/2012 12:52)P528LND Wrote:  I don't think that happens often, I've never personally seen an Enviro400 on Magicbus duties! Smile
It does happen from time to time. I've seen 19394 and 19395 doing Magic Services on a couple of occasions.
I think there might be a shortage of Magic Buses now Uni's are back, with the Olympians having been withdrawn.
16798/99/800 still in use 16793/95/97 are back
So 16793/95/97 rejected by Kent then presumably. If they are all still any good that would solve the shortage, if they could last 'til the New Year when the tridents currently at Stockport will be available.
(24/09/2012 18:44)ace Wrote:  It does happen from time to time. I've seen 19394 and 19395 doing Magic Services on a couple of occasions.
they where only on loan 16090/16509/16792 are also due back
(24/09/2012 18:56)mic Wrote:  16798/99/800 still in use 16793/95/97 are back
I'd be surprised to see 16090 back on the road. Last time I saw it, some months ago now, it could barely stand up on its own.
It happens every single night usually a Sharston bus
(24/09/2012 19:09)ace Wrote:  So 16793/95/97 rejected by Kent then presumably. If they are all still any good that would solve the shortage, if they could last 'til the New Year when the tridents currently at Stockport will be available.
Nothing wrong with 16090 it has been a regular on the 99 Wave route from Silverhill to Eastbourne along with guest appearances by 16509 and 16792 so they should be fit to work the 142/143 route.
