Current time: 20/11/2026, 02:15 Hello There, Guest! (Login — Register)
^ The signage on a 185 attempts to direct all the standard class passengers (apart from the ones sat in the little section between FC and the cab) to the second toilet in carriage B.
I still walk through first if I'm in that coach, no as do people who need the bigger loo with its baby changing facilities and so on.
SD.
319361+319362 both at Wolverton.
Hence above 156488 worked 0716 Lime St-Man Air (wedgio) and 0840 Man Air-Lime St
1316+1616 Lime St-Man Air and 1440+1740 Man Air-Lime St all cancelled due to 156488 failing
(13/02/2017 16:41)Gordon V Wrote:  319361+319362 both at Wolverton.
As well as overhaul, do you know if they are being repainted and getting Wifi fitted as part of this work?
(13/02/2017 17:00)St Helens Rider Wrote:  As well as overhaul, do you know if they are being repainted and getting Wifi fitted as part of this work?
Don't know I am afraid all will be revealed when they leave Wolverton!
(13/02/2017 17:06)Gordon V Wrote:  Don't know I am afraid all will be revealed when they leave Wolverton!
Many thanks. I'm sure we'll know in the fullness of time.
142011 has just past Thatto Heath on the Express to Liverpool!
(14/02/2017 12:14)T42 PVM Wrote:  142011 has just past Thatto Heath on the Express to Liverpool!
It's been on the Preston line since 0657 ex Lime St
86259 and 47815 top and tailed 319450 from Wolverton Works to Allerton MPD today. It must be many years since Allerton played host to an electric locomotive. 319450 is white with blue doors.
(15/02/2017 18:49)childwallblues Wrote:  86259 and 47815 top and tailed 319450 from Wolverton Works to Allerton MPD today. It must be many years since Allerton played host to an electric locomotive. 319450 is white with blue doors.
So this will be the first 319 in new livery by the looks of it.
