Current time: 07/11/2026, 05:24 Hello There, Guest! (Login — Register)
More changes to the 88/89 from 28th April. As well as the TfGM funded evening/weekend Wilmslow-Altrincham journeys there's some 'relaibility improvements' which include re-timing services, changing the amount of padding and increasing turnaround times.
Also D&G website says a X41 Stafford-Uttoxeter - Alton Towers service starts in May with timetable to follow.
The 10.8m Enviro200s and the Solo SRs 101-106 have shorter wheelbase than the big Solos which makes them more manouvreable. The Taxis in Wilmslow station aren't too much of a problem. It's the brain dead morons in cars picking up or dropping off passengers that just park where they want. The SRs were lilely used to upgrade other routes, 3 of them have now moved to Longton.
(11/04/2019 17:24)knutstransport Wrote:  When GHA used 10.8m Enviros on the 88 poorly parked cars on Chapel La, Wilmslow seemed to caused more problems than the preying taxi drivers overcrowding the taxi rank at Wilmslow St.
The D&G Solo SRs seemed to work well on the 88. I'm not sure why D&G thought it was a good idea to replace them with other buses.
Works for me
Current allocation at Winchem is 2 Solo SRs
5 Enviro200s
7 or 8 normal Solos
You have too many 'normal' Solos.
Enviro200 30,31,32,33,53
Solo SR 105,106
Solo 45,129,131,137,140,141
Since SRs 101-103 moved to Longton big Solos in the series 137-141 have been turning up here.
(14/04/2019 18:42)M60lad Wrote:  Current allocation at Winchem is 2 Solo SRs
5 Enviro200s
7 or 8 normal Solos
Works for me
(15/04/2019 00:33)Rick Hunter Wrote:  You have too many 'normal' Solos.
Solo SR 105,106
In 2019 you could argue a SR is a normal Solo and the rest are old Solos or perhaps classic Solos.
As there are currently only 2 SRs at Wincham the 'classics' are most definitely the normal
(15/04/2019 16:24)knutstransport Wrote:  In 2019 you could argue a SR is a normal Solo and the rest are old Solos or perhaps classic Solos.
Works for me
(15/04/2019 22:15)Rick Hunter Wrote:  As there are currently only 2 SRs at Wincham the 'classics' are most definitely the normal
Using that logic only the longer 55 reg ones are the normal ones, as the rest are short Solos and the ex-airport one doesn't have the same exterior lighting as the ex-Go Goodwin's ones.
D&G have lost the contract for the Little Bus services to Cheshire East owned Transport Service Solutions: http://www.wilmslow.co.uk/news/article/1...e-upgraded
(16/04/2019 19:45)knutstransport Wrote:  D&G have lost the contract for the Little Bus services to Cheshire East owned Transport Service Solutions: http://www.wilmslow.co.uk/news/article/1...e-upgraded
I think the first comment on the article says it all really doesn't it.
82 branded Enviro on the 1745 88 Altrincham to Knutsford. It looks to have taken the place of a Solo SR which was on the 88/89 earlier.
