Current time: 20/11/2026, 01:32 Hello There, Guest! (Login — Register)
Northern Rail
RE: Northern Rail
No, the unit for the morning services runs ECS from Lime St to Bank Quay, does a couple of trips then it goes empty from Bank Quay to Preston.
The unit for the afternoon trips comes from Chester and after it has done a couple of trips runs ECS from Bank Quay to Lime St.
SD.
RE: Northern Rail
Thanks SD.
RE: Northern Rail
Happy to help!
SD.
RE: Northern Rail
(07/09/2015 12:07)wirralbus Wrote:  Isnt that a terrible waste of resources coming ECS that far .
Welcome to the privatised railway...
ATW send 2 x 175 ECS CTR to LLJ every morning and 1 ECS CTR - PICC via Crewe/WBQ, also 3 x 15x CTR - LLJ every morning.
East Mids send 3 x 158 ECS Nottingham to Lime St... Every morning..
Virgin runs Voyagers galore ECS between Crewe/Tamworth - Chester/Holyhead /Wrexham, every morning/evening..
RE: Northern Rail
Why cant that last trip not continue in service beyond Helsby and Warrington Bank Quay.
I suppose it is more to do with the fact that the service arrives at Warrington Bank Quay to fit into the pattern at Earlestown at the wrong time , the Non-stop service TPX precluding anything other than an ECS working.
What does the set strengthen at Liverpool Lime St.
RE: Northern Rail
It used to work the 1725 from Lime St to Oxford Rd, not 100% sure, will find out.
As for a waste of resources it isn't quite as bad as the four units that come from Nottingham to Liverpool to work the first departures to Norwich.
SD.
RE: Northern Rail
In what would have been a rare sight even six months ago 150136 was on the Sheffield-Scunthorpe service whilst 150112 was on the Lincoln to Adwick.
RE: Northern Rail
319376 is the latest of the class to arrive at Alperton.
RE: Northern Rail
142 030 on 1503 Blackpool North - Liverpool South Parkway - not seen a Pacer on this route for a while as the route appeared to have settled to a150/156 mix.
RE: Northern Rail
On long welded rail i find the 142's acceptable , its only when you get on to short length track that the ride becomes intolerable .
The bank from Springs branch to Bryn up the incline used to be terrible as you had a PSR and short length track which would make the run an eternity in that direction.
