Current time: 30/11/2026, 20:41 Hello There, Guest! (Login — Register)
(03/01/2019 17:27)Mayneway Wrote:  Blimey I'm surprised by that. There was a shortage over Christmas and at least 2 long term VOR's were towed from Ashton to Sharston because Ashton fitters were so busy it sounds like the breakdowns are continuing into the new year.
And it seems to be continuing; 19282 & 19352 seen at the Airport on 330 today - yes, Sunday!
Due to upcoming roadworks on M56 Sharston Link this weekend the Sharston Link of M56 will be closed Eastbound (heading away from the Airport) from Friday 21:00 until Monday 05:00 obviously this will mean diversions to all 330s heading away from Airport, not to sure of the diversion yet but guessing Stagecoach will put up the diversion later this week.
The Diversion for normal traffic is Princess Parkway then onto M60 at J5 then off at J6 round the roundabouts and back onto M60 then back onto normal route at J4, not to sure if Stagecoach will take this route or will avoid the Motorway altogether.
(08/01/2019 07:11)M60lad Wrote:  Due to upcoming roadworks on M56 Sharston Link this weekend the Sharston Link of M56 will be closed Eastbound (heading away from the Airport) from Friday 21:00 until Monday 05:00 obviously this will mean diversions to all 330s heading away from Airport, not to sure of the diversion yet but guessing Stagecoach will put up the diversion later this week.
On the previous westbund diversions both stagecoach and high peak have officially followed that diversion.
Edit : but those were night time only. I wonder if they might use m60 - a34-a555.
Just seen the new timetable for Stagecoach's 230/231 route:
https://tis-kml-stagecoach.s3.amazonaws....JAO230.pdf
Not to sure of the route 230 is going to take but it seems that most journeys during the daytime on 230 will be leaving Ashton about 1 minute before 231 although getting into Manchester earlier than 231. Going the other way it seems that most daytime journies on 230/231 will be getting into Ashton Bus Station at the same time as each other.
Timetable for the new 150
https://tis-kml-stagecoach.s3.amazonaws....JAO150.pdf
(08/01/2019 20:28)M60lad Wrote:  Just seen the new timetable for Stagecoach's 230/231 route:
Apparently it follows the 168 route from Ashton (along Taunton Road, Newmarket Road etc) all the way to market street in Droylsden where it turns right onto Manchester road and then passes Tesco and follows normal 231 route into Manchester. It's the same the other way.
Had a ride on 19189[Magic Bus] on the 42B at lunchtime.
(09/01/2019 12:18)Mayneway Wrote:  Apparently it follows the 168 route from Ashton (along Taunton Road, Newmarket Road etc) all the way to market street in Droylsden where it turns right onto Manchester road and then passes Tesco and follows normal 231 route into Manchester. It's the same the other way.
Are you sure about that as Clayton, Aldi not a timing point but Droylsden, Cemetery Road Tram Stop (Stop A) is so could turn off onto edge lane and north road
Not to sure whether or why it would go via Edge Lane and North Road as doesn't MCT's 217 do the same route, mind you it would be a viable alternative to 217 if 230 did go this way.
(09/01/2019 18:01)Mrboo Wrote:  Are you sure about that as Clayton, Aldi not a timing point but Droylsden, Cemetery Road Tram Stop (Stop A) is so could turn off onto edge lane and north road
Only repeating what I was told by an AZ driver.
