Current time: 04/11/2026, 15:17 Hello There, Guest! (Login — Register)
(28/10/2018 09:14)MTL0201 Wrote:  Latest
Service 16/17: Moreton Cross – South Wirral Circular
Services will be re-instated as previous route, but will be extended to operate a circular route via Spital, Eastham,
Mill Park & Raby Mere giving links from South Wirral to Arrowe Park & Clatterbridge Hospitals.
Every 30 minutes (combined) Mon-Sat daytime.
Service 22: Chester – Moreton Cross
Service will be extended to operate through Sandbrook Estate.
Every 60 minutes Mon-Sat daytime.
Service 38: West Kirby – Eastham
Service will be extended to/from Eastham Ferry.
https://www.merseytravel.gov.uk/travel-u...-11-18.pdf
Although this extension of route 38 will supposedly cover the eastern section of former route 85 (Heswall - Eastham) it will inevitably take longer for going via Birkenhead * West Kirby. I'm pretty sure some roads further along route 85 might no longer have a bus service even after Monday's changes.
36315 and at least one other are in the yard at RF this afternoon.
HTH
(03/11/2018 06:14)Metroline1511 Wrote:  Although this extension of route 38 will supposedly cover the eastern section of former route 85 (Heswall - Eastham) it will inevitably take longer for going via Birkenhead * West Kirby. I'm pretty sure some roads further along route 85 might no longer have a bus service even after Monday's changes.
With the 38 alteration is this with an increase in PVR or the same as before .
(03/11/2018 20:03)wirralbus Wrote:  With the 38 alteration is this with an increase in PVR or the same as before .
Same PVR. they have reduced time between Croft and Mill Park to enable the extension. Still 3 minutes layover though.
Variation to the Mold 5/5As from December 2nd.
https://www.vehicle-operator-licensing.s...ls/526839/
Apparently they want to bring it out of Aston Hill. Could it be to do with that? I wish they would bring back the SPs. They were so much better and busier. Just needed a few timing changes.
(03/11/2018 20:43)iMarkeh Wrote:  Apparently they want to bring it out of Aston Hill. Could it be to do with that? I wish they would bring back the SPs. They were so much better and busier. Just needed a few timing changes.
I heard either Aston Hill or Nant Mawr Road in Buckley.
36314/7 in Rock Ferry depot today http://www.flickr.com/photos/dmc1947/43896640860 http://www.flickr.com/photos/dmc1947/43896640450
36319 http://www.flickr.com/photos/dmc1947/43896640090
HTH
Good to see 36319 has arrived, that is the only one I hadn't seen at Gillmoss
(04/11/2018 14:21)buses7675 Wrote:  Good to see 36319 has arrived, that is the only one I hadn't seen at Gillmoss
Just checked on London Vehicle Finder and it was in use in the Romford area (on the 193) until 5 days ago.....
HTH
User(s) browsing this thread: 51 Guest(s)
